Wiper Motor Repair
  • Morris Van Horne
    I cleaned (Emory paper on the armature and inside) and lubed the Bosch unit. The original brushes were riveted in- cut them out, leaving about 1/4 inch of the original braided wire attached to the housing, then just soldered in the new brushes to that pigtail. To hold the brush/spring assembly back to allow assembly, I used some braided wire to cradle them back and over the outside of the end cap. The new brush wires were used to pry each back. Once the end cap was partially positioned with a small gap, it was easy to remove the cradling wire to let the brushes seat in.
  • 1953champcoupe
    I too, would suggest that you do a little cleanup on the unit, I had three wipers, one six volt, two 12 volt (which was what I was going to use) none of them worked (well maybe the six volt did but I didn't check) I ended up doing a partial disassembly, a clean up job & lube (and stupid me had cut a couple of tiny wires that had to be resoldered/connected) and by some stroke of good luck it worked. I suspect you are as good a fabricobbler as I
  • Al from Eatonville
    Thank you again. Every little bit of information helps.
  • Morris Van Horne
    I am not sure about Bosch vs Redmond- here is a pic of my wiring I took to make sure I reassembled it- not sure if it will help or not.
  • Morris Van Horne
    Thank you Morris. Perhaps all is not lost after all. One question though: I have a spare Bosch motor that works somewhat but the one already in the car is a Redmond. If I rebuild the Bosch motor as opposed to rebuiding the Redmond motor, can I still use the existing switch or do I need to change out the switch to accommodate the Bosch motor? Your thoughts are appreciated.
  • Morris Van Horne
    I just spent the last 2 days working over the wiper system on my 54 Commander. Ordered new brushes from a Studebaker vendor, used the shop manual to pull the motor (also pulled the arms under the dash, cleaned and lubricated all pivots, then pulled the motor apart- had to unsolder one wire to get the end cap off, cut the original brushes out, soldered the new ones in, lined, then reversed the process. I bench tested the motor- both speeds worked perfectly, then reassembled everything. The issue Ifound was that one of the brushes was hung up in its keeper inside the motor casing. The final test was when I used the wiper switch, and nothing worked! Looked over and saw the key was in the off position! All was well once energized, and the motor was strong in both high and low speeds (Bosch 3-wire motor) Should be good for another 67 years or more!
    Hello Ross and thank you for that suggestion. I will give that a try and keep you all posted.
  • Ross
    Before going to a lot of trouble, pull off the cover plate and squirt a little oil on the worm drive and shaft to soften up that ancient grease a bit. That might fix you right up for all of ten minute's work.
    Thank you so much for the 2 referrals. Not sure how I'm going to go with this, but informed referrals are always better than "shooting in the dark".
  • rockne10
    These folks rebuilt the wiper motor for my '51 Commander.
    http://mykmlifestyle.com/
  • Bo Markham
    We can rebuild your unit. Markham Motors, 6451 SE 180th Ave. Morriston, Fl. 32668.
    Bo
    started a topic Electrical: Wiper Motor Repair
    Wiper Motor Repair
    My car is a 53 Commander Coupe with 6 volt and positive ground electrics. My Redmond windshield wiper motor is very much in need of repair/rebuilding. It still works, but barely. Does anyone out there rebuild them or should I just start looking for a repacement? Any and all thoughts would be appreciated. Thank you in advance.
