Hi everyone, first post on the forum. I just bought a '63 Lark last week. It's pretty much bone stock and in great shape. I even got the entire factory a/c system, it's in a box right now though. I'm going to take the car up to South Carolina next week for the wife to drive. The family has relocated ahead of me until I retire in a couple of months and I want to get the air going. I've done some reading about using a Sanden compressor to replace the York but haven't been able to pinpoint which compressor to buy. I know I need an adapter bracket to make it work. Just trying to find out which compressor I need to pickup. Thank you in advance for any input.
'63 Lark A/C compressor question
Most use the 508 model. That is also what most adapters are made to fit.Bez Auto Alchemy
Joshua, is your Studebaker a V8 or a six cylinder? The commonly available adapters to fit the Sanden 508 will work fine with the factory V8 ac compressor bracket, but will not be a 'bolt on' for the six cylinder engine. The six cylinder will require some additional fabricating to make the Sanden work with the factory brackets (due to the design of the original six cylinder factory bracketry).
R12, if you can find it, is likely $200+ per pound. At 3 pounds for a fill, you should reconsider springing for the sanden upgrade.78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
55 Speedster 7160047
55 Speedster 7165279
A friend of mine in the A/C business has a storage of some but eventually the R-134 will be replaced. He also is a car guy but the wrong brand. He says First on Race Day but I say Fraud on rally day.
I would say that $200 per pound is a low estimate. In Arizona, most have converted to R134.
Bob Miles
At 80 mph, there is enough airflow to cool you down with the windows open
This is the simple bracket I made to use a Sanden compressor in place of the York unit. It simply bolts in place of the York compressor on it's bracket and the Sanden bolts to it. It's made from 2" x 1/4"angle iron.
Here, it's bolted to the York bracket
Here's the Sanden bolted in place.
image widget
There are brackets as well as kits available on ebay for reasonable prices. You could also look in the classified section of Turning Wheels. Even if your York compressor is good, you would likely need new valve, dryer/accumulator, and hoses. You may need new evaporator and/or condenser as well.78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
