1950 Champion. 1" wheel cylinders in rear?
  • Brakes: 1950 Champion. 1" wheel cylinders in rear?
    I am recently retired and getting my 1950 Champion running again. When I get to that point I will be concerned with getting her stopping again. I plan to do Turner discs on the front and was wondering if there would be an advantage to putting 1" wheel cylinders in the rear instead of the stock 7/8". It appears they would bolt in and line up correctly with the shoes. Any ideas on this?
    Welcome to the SDC and to the SDC Forum Hank!
    Good to have another Washingtonian here!
    These 1 Inch W/Cylinders must be for a R Series Truck.
    Usually you lessen the Rear Braking with Front Discs. if they are on a Car where there are no Heavy loads on the rear.
    If you have a fairly Good stock brake setup on the rear now, I would try it out First, before "experimenting".
      i don't know what is going on, but my drums brakes on my 60 v8 lark feels stopping better is improving the more i drive it, and the rebuilt 289 is no slouch
        They are the front ones from the same car.
          The advantage to having smaller diameter rears is it takes less line pressure to operate than the larger diameter,; I’d stay with the stock size.
