Differential oil
  • Rear Axle: Differential oil
    Servicing the Twin Traction in 63 R1, what is preferred oil now adays
    The Brand is not as important as the API Grade, it must be Hypoid Gear Oil GL-5, The Weight is 90 or 80W/90, and if you do a full drain, add the Friction Modifier, Limited Slip Additive usually a 4 OZ Bottle will do, and follow the directions on it.
    Buy a Good Brand though, like Valvoline or Sta-Lube.
    I go to a Jeep Dealer to get the Dana approved additive, but Parts Stores carry the alternative to OEM Factory stuff.
    I would think that 4X4 Shops do also.
      Thank You for information
        I have been using Amsoil Severe Gear 75W-110 full synthetic gear lube in my cars with excellent results. It has the friction modifiers for Twin Traction already included. I believe that most of the full synthetic lubes such as Valvoline and Mobil 1 also have the limited slip additive included too. I will say that Lucas full synthetic gear lube caused clutch chatter in my Avanti and also in the differential of a friends Corvette. Synthetic lubes are more expensive but since they are changed infrequently, the added protection from the synthetics are well worth the extra money. Bud
