'52 Commander clock black light not working - bulbs work
  • #16
    bezhawk:
    Thanks for mentioning the side windows.
    I suppose I can see one of the rivets that you referred to in the fourth image here:
    http://www.2040-parts.com/vintage-19...-borg-i681693/
    (I'm not planning on drilling the rivets.)
    It just occurred to me that perhaps I could blow air up there to clear dirt away.
    And that I could try to do some more cleaning, not just on the inside of the filters but on the outside as well.
    I'll give that a try (another day).
    • #17
      I have a 50 Commander with very low miles and the instruments and speedo glow very nicely as they have never been sunburnt. The clock has the same symptoms as yours and a very careful cleaning made no difference. At night it is only just visible. Chalk it up to a design flaw.
      • #18
        52 Commander Thank ya for the update!
        I'm still learning here too... Had no idea about the solarization issue with Wood's glass, but have noted it in old sidewalk light prisms. Oddly enough, that's a reaction to the manganese dioxide that was added to glass to initially make it clearer. I doubt this would be an issue in your gauges with the relatively minor amount of ultraviolet that an incandescent produces; probably more so with gas discharge lamps like fluorescent and mercury vapor, as much of their output is shortwave UV. Also sounds like chemical reactivity of some components of Wood's glass to moisture and carbon dioxide might have a little effect on its stability. I am still betting that the phosphorescent paint is the weakest link
        Whirling dervish of misinformation.
        • #19
          I guarantee the weak link is the lack of ultra-violet light reaching the phosphorescent face. Every time someone tells the forum that they shine a UV light on the gauges, and they glow like new...it never "clicks" with the rest of the commenters that hey, maybe we need more UV .
          Bez Auto Alchemy
          • #20
            Not trying to get in a urinating distance match with you, but I'm still wondering how these gauges managed to glow adequately with the weenie incandescent bulbs when they were new. No one shuffled the location of the lights or the light source over the last 70 years, so what's left?
            • #21
              No peeing is needed! . What I'm not so succinctly trying to convey, is yes, the "glow" is now degraded over the years as the paint looses it's phosphorescence capabilities. But that it can be further enhanced to work better than new with upgraded UV. Yes, they are weaker now because of the filters degrade AND the paint oxidizes and looses it's ability to absorb energizing photons. Short of taking the gauges apart, and cleaning the faces (which I do) the average person CAN achieve good results with improved ultra violet lighting.
              What is left is go out and but some UV lights. Why not try it instead of arguing the point? There is NO way to have them work as new after 70+ years unless you find NOS that has been stored in a dark cave away from pollution, ozone, and sunlight.
              Take into account that, yes, that they are now 70 years old. Also, that the glass has darkened, and collected dirt. That the zinc phosphate paint has oxidized. That the "windows" on the side of the instrument has oxidized, and are not as transparent. And finally, that our eyes are not as good as they used to be! .
              Bez Auto Alchemy
              • #22
                Ross thank you for your observation - I'll set my expectations low! (but still above zero) :-)
                Given that the clock paint glows brighter than the speedometer paint (using an external black light) I expect that something in the clock will light up if I can get the "light path" clear. Even dim lighting will be much better than what I have now.
                Lark Hunter You're welcome!
                ( bezhawk Brad - I'm nodding to your comment that our eyes aren't as good as the used to be...)
                I ordered a wireless endoscope today to (hopefully) enable me to see better what is up under the dash (while saving my back and neck some contorting too).
                (if it works well) I'll learn what is up with those "windows" and perhaps I can use it to better direct some WD40, and some air pressure at all related surfaces (in and out of the glass, and on the window) to clean up the light path.
                I looked for UV bulbs that would fit the ba9s socket here, didn't see any:
                https://www.bulbtown.com/SearchResul...how=300&page=1
                Brad, have you found UV bulbs that fit the stock socket?
                Ah, how about this: https://www.titanpinball.com/index.p...product_id=150
                Later,
                Scott
                • #23
                  Originally posted by 52 Commander View Post
                  /Cut/
                  This is the first that I noticed that the PNDLR indicator lights up (dimly) too.
                  If that Lens is not really dirty, THAT is making me wonder if some of your problem is Low Voltage, poor connections, weak grounds etc.
                  Does the Battery Voltage read over 6.0 and over 7.0 running?
                  Usually these small #51 and Larger #53, 6 Volt bayonet based Bulbs are reasonably Bright.
                  • #24
                    52commander If you get UV bulbs from them, please report back on how well they work, good or bad.
                    The picture of the bulb that looks most intriguing is the side-projecting surface mount that they picture. Unfortunately they don't show that as a choice. I learned from soldering up my own UV LED bulbs, that we need the UV light going sideways. An LED's narrow beam doesn't seem to bounce around much within our instrument cluster.
                    • #25
                      Champ51 I just took a look at that site and the photos. I see what you mean.
                      To buy the side-projecting SMD (surface mount diode) version first pick the Bulb - Base = 44 Bayonet (BA9S). Then pick the Bulb Style = 5 SMD Tower.
                      StudeRich Excellent point. To support what you wrote:
                      a) IIRC the voltage at the trunk light was 4.72 volts (when I measured it months ago - the engine was not running).
                      hmm. although when debugging the convertible top not working there was a full 6V at the motor
                      b) when out driving two days ago in bright daylight the guy behind me told me that both brake lights were not working. At night in the garage, with the brake lights less than a foot from the garage door, I stepped on the brake pedal and only a very faint bit of red light illuminated the white glossy garage door.
                      I'll be out in the garage with a voltmeter at some point. This is my Uncle's car. He lent me it to have fun with. (Great guy!) I decided to try to fix some minor things (that I thought would be easy to fix!). (replacing the map light was quite challenging!)
                      If you have tips on finding the problem I'm all ears. I just plan to measure the voltage at different points, starting with the battery itself. And maybe take the battery cables off and wire brush 'em a bit. All of this is new to me - and I'm having a lot of fun with it! I didn't even know that it was a 6V system until a friend (who was a mechanic) told me about that. I did learn that the system has a positive ground reading this forum.
                      Peace,
                      Scott
                      • #26
                        There is a procedure for adjusting the voltage regulator. If it is not covered in the shop manual, I have seen it in older Motors manuals. I believe you want 7.4 volts running .
                        Bez Auto Alchemy
