Door Hinge Pin Removal, 1929 President
  • Body / Glass: Door Hinge Pin Removal, 1929 President
    What is the best way to remove the door hinge pins on a 1929 President. I tapped on one a little but it didn't move so before I mess it up I thought I would ask. Thank you
    Welcome to the SDC, and to the SDC Forum Paul.
    The viewers here and the Administrators Prefer a descriptive TITLE like: ('29 Pres. Door Hinge PINS) that can be Searched by others needing the same advice in the Future.
    Your Name (Handle) is not a Good Title.
    Please try updating your title, it also gets better results, it's at the Bottom Right of this Post called: "Edit"..
      Agreed.
      I had the same issue on a '46 Chevy. I just soaked them in liquid wrench for a week or so then used a punch about the same size as the pin to punch them out.
        They probably have a knurl on the end to help hold them in place, and it will take more than a tap to drive them out. Bead blast the part,(especially the head), to see if someone brazed the pin in place. A lot can happen in nearly a century. Also, use a little heat to break any rust bonds. I don't think you have to worry about any plastic melting!
        Bez Auto Alchemy
