OHV main bearing woes
Problem is you are using 'partial-flow' bearings in a 'full flow' block. You may have problems using the 185 crank in a full flow OHV block due to the oil passage pattern drilled in the crank. Not sure
When I built my OHV 185, I used a 61 block that was partial flow to avoid such problems.
Dwain just responded with a service buliten I haven't finished printing yet. The parts manual does not show any difference between partial flow and full flow mains, just cam bearings. A quick scan of the service buliten seems to show a different part number.
I'm too tired to look further tonight, but I do think that you (and he) are right, and the parts book is wrong.
Ron Dame
'63 ChampRon Dame
'63 Champ
I'm going to stick my neck out and say that you can drill the bearings (very gently). The oil will pass through the bearing to the groove, where it will travel to the hole in the web then to the rod and thence to the rod bearing. I don't believe the position of the crank oil passage and the rod oil passage is critical.
[Edit, added thought] I can't see that there would be one good place that the rod bearing needs more oil than any other.
I'm willing to be corrected, but you gotta convince me.
Tom Bredehoft
(Under Construction 571 hrs.)
'05 Legacy Ltd Wagon
All Indiana built cars
I'll pass on the drilling. I don't see it as a problem for someone else to do, but me? That could be a big problem! I'm just thankful that when I put the bearings in I looked and saw that something wasn't right...I wouldn't have even broken in the cam before it blew up.
Tom Bredehoft
'63 ChampRon Dame
'63 Champ
I don't understand how a 185 crank in a full flow block woud make any difference. What will get blocked? I'll have yet another look and see. This is getting real tiresome, one problem after another, but I'd like it to work right, of course. The crank should still get oil and feed it to the rods, the oil holes in all of the bearings, the block, and the rods are in the center of the bearings, so I'm not clear what would get blocked in this configuration.
But please, if you know, please please tell me.
Ron
'63 ChampRon Dame
'63 Champ
With credit to Dwain Grindinger, here is the appropriate information from Studebaker Service Bulletin #S-1048:
MAIN BEARINGS - 1962 MODEL 6-CYLINDER PASSENGER CARS WITH FULL-FLOW OIL FILTER SYSTEM
1962 model 6-cylinder passenger car engines equipped with a full-flow oil filter system require main bearings that are different from the main bearings used on models without the full-flow oil filter system because of the location of the main bearing oil lubrication holes.
Service main bearings, either individually or in sets, used in 6-cylinder engines without the full-flow oil filter system must not be used in engines equipped with the full-flow oil filter system, with the exception of the rear main bearing. This bearing is common to both engines.
However, service main bearings released for the 6-cylinder engine with the full-flow oil filter system can be used in engines without the filter system.
Yep, Dwain forwared me the service bulletin. The numbers in my parts book are correct, but I went to the garage to look at the bearing box again: The box has the correct part number pencilled in on it, but under the masking tape that closed the box is the Studebaker label, torn faded, etc. It has a different part number on it. I suspect whoever I bought these from several years ago when I started the project (I no longer remember who) substituted older partial flow bearings without realizing the difference.
My machine shop is concernd about drilling new holes in the shells, for fear of tearing the bearing material from the shell. An I know I'd really doink them uf if I tried. So I'm starting to look for some. If anyone has any P/N 1556298 0.010 undesized mains on the shelf they don't want, please let me know! (SASCO, Chuck Collins, and Studebaker International show no-stock, but I'm still looking.)
Ron
'63 ChampRon Dame
'63 Champ
We used to use a milling machine to create dowel holes in steel backed rod bearings successfully, before the bearing companies started making 'racing" bearings. Today I'd clamp the bearing against a wood 2X4 (or better yet, hardwood) with a contoured edge so the drill would not tear things up too badly when breaking thru. I'd test on an old bearing first to get the feel for it. When done I'd use a cutting burr, not a stone in a hand grinder or Dremel to chamfer the babbit side and deburr the steel back.
So, if the service main bearings are double-drilled, it makes sense that one could re-drill the the single-drilled bearings, if they were otherwise right.
I'd do it in the drill press, starting with a bit small enough to turn in the oil groove without snagging the sides, and then gradually work up to the finished hole size. Then finish with a countersink. Should be minimal chance that way of damaging the bond between the bearing and the shell.
Gord Richmond, within Weasel range of the Alberta BadlandsGord Richmond, within Weasel range of the Alberta Badlands
Well, I'm hosed!
I had purchased three sets of Clevite aftermarket main bearings of various undersizes from a guy in Texas (Houston?) that (I thought) were advertised as fitting all '55 thru '64 Champion-style six cylinders. They were going to be used on my two 185 OHV (full flow) engine conversions.
After seeing these posts, I decided I better check them since I didn't remember them having two oil holes. Shoot....they only have one oil feed hole - and it lines up with the oil holes in the partial flow blocks.
Live and learn I guess.......
Paul
Winston-Salem, NC
Visit The NEW Studebaker Skytop Registry website at: www.studebakerskytop.com
I was always taught that bearings should never be touched by fingers, as the acid in your fingers can damage the surface and lead to premature failure; so it follows that there is NO way I'd be comfortable drilling any[:0]
Parish, central NY 13131
This is a quote from Dick Daton's Stude 'high performace book':
" It is easy to put togther a Stude six from misc. parts as there is a great deal of interchangability. There is however, a little bit of risk here which we have tried to point out ----
I have checked a 185 crank against a 1964 180 crank and found the oil holes to the rods are drilled at different locations on the two center main bearing journals....What does this mean? If you plan to build a 185 OHV or put a 61-63 crank in a 63-64 full flow OHV sic blocl, you may encounter the same problem the factory had with using full-flow blocks and non-full flow cranks. IF you use a non-full-flow block ('61-62) you should be safe. A 185 crank in a late full-flow OHV block should be possible (using late main bearing sets) even though it will oil differently since the bearings are grooved and the early crank cross-drilled. "
