Champ windshield removal
  • Body / Glass: Champ windshield removal
    I want to remove the windshield from my Champ, to do cab repairs. The service manual seems written for someone who knows what they are doing. I don't. I have searched here and on Google, for Champ and Lark windshield removal, and not found much. I don't care about saving the rubbing molding/gasket, as I want a new one. Any advise on removing the windshield would be appreciated.
    Mike and Dawn
    '61 Champ
    The Shop Manual tells you what you won't find on Google.
    If there is any flexibility left in the old rubber you should be able to push the windshield out by starting gently in either top corner.
    But most of us just use a box cutter and make a messier job.
    '33 Rockne 10,
    '51 Commander Starlight,
    '56 Sky Hawk
      Thanks for the reply. What confused me about the service manual, is it says to push the windshield into the inside of the cab.
      Mike and Dawn
      '61 Champ
        It must be talking about a "C" Cab, not a "T" Cab.
          Ok, thanks for the clarification.
          Mike and Dawn
          '61 Champ
            Be careful about pushing windshields out. I have done this many times. I am not a huge guy so sitting on the front seat and using my legs I push the windshield out with my feet, much easier than with hands..
            I did this with a 59 Lark I bought for parts but had no idea it had a laminated screen. What a disappointment when is flexed and cracked.
            I have pushed out a laminated screen before on a Saab but I knew it was laminated from the start.
            Cut out a laminated screen push out a safety glass screen.
              If you are replacing the rubber, just take a razor knife and trim off the inside lip of the old rubber. Then the laminated glass will push right out of the opening. Laminated will definitely crack with too much pressure in one spot. Good Luck!
                Thanks for the information, I never knew there was a both laminated and safety glass, thanks.
                Mike and Dawn
                '61 Champ
                  Thanks, we were able to cut the gasket, and the windshield came out very easily. The back window looked to have some sort of goo with the gasket, took some pushing to get it started, but the windshield took no real pressure at all to remove.
                  Mike and Dawn
                  '61 Champ
                    Mike, if you need help installing the new windshield let me know and I will get you in touch with the installer I used.
                    Ed Sallia
                    Dundee, OR
                    Sol Lucet Omnibus
                      Thanks, I actually would prefer someone qualified to install it back in. Probably be a few months though.
                      Thanks!
                      Mike and Dawn
                      '61 Champ
                        Make certain they use enough bedding compound. Extra that oozes out can always be wiped away; but not enough means it will leak.
                        '33 Rockne 10,
                        '56 Sky Hawk
                          Thanks for the heads up!
                          Mike and Dawn
                          '61 Champ
