Hood hinge
  • Frame / Springs: Hood hinge
    Hood on my 54 Coupe very hard to raise. Is there any type of hinge maintenance or adjustment to make it easier to raise?
    Inspect hinges for wear. Oil hinges. Replace all 4 springs if missing or tired. Pull toward you when opening. Be thankful its not a Hawk.
      Thanks for the suggestions. I’ll start on it tomorrow.
        What Jim said!
        All C/K hoods are heavy; add the weight of the Hawk grill, and raising it is a question of mind over matter, unless everything is lubricated and adjusted as when new; and then still a task.
        A small price to pay for possessing these magnificent road machines.
        '33 Rockne 10,
        '51 Commander Starlight,
        '56 Sky Hawk
          I actually have a slight bend in the sheet metal at the rear corner of my hood above the hinge. Not sure when I did it but the hood has always been a chore to raise. Know idea what to do about the bend.
            Originally posted by Ron Plantz View Post
            Know[sic] idea what to do about the bend.
            A body shop can straighten it.
            Classic Enterprises has produced a reinforcement for the notorious hood corners, which are usually deformed when owners don't realize the hood needs pulled forward before, or in the process of being raised.
            https://www.classicent.com/studebake...-hawks/Support
            '33 Rockne 10,
            '56 Sky Hawk
              The kit looks like a good preventative option. Does the typical kink repair involve a repaint?
                Depending on severity, and skill of the body shop, quite probably.
                '33 Rockne 10,
                '56 Sky Hawk
