P.S. Steering wheel violently steers itself back and forth
  • Steering: P.S. Steering wheel violently steers itself back and forth
    Hi Guys-- I bought used P.S. system complete off of a '63 Cruiser/289, and installed it into my "63 Wagonaire/289. It installed bolt for bolt. I replaced all hoses with new from S.I. and had the control valve rebuilt by Lares. The pump and ram are used but look clean. The Cruiser parts car had sat in a field for many, many years, but was a fairly low mileage car when parked (90K).
    I filled with new fluid and started the engine. All was well, until I touched the steering wheel . I was going to turn it back and forth to bleed the system. As soon as I moved it, it suddenly began whipping back and forth, about a full turn either direction, with enough force to break my fingers if they were in the wheel! The only way to stop it was to shut the engine off. Then, I restarted it, the wheel was still, until I moved it again, whereupon it immediately began violently whipping back and forth again. So I shut it off again. Anybody seen this before? I fee pretty certain I installed the lines correctly (although I'm man enough to admit if I'm wrong)... so what the Devil is causing this?
    1950 Commander Land Cruiser
    1951 Champion Business Coupe
    1951 Commander Starlight
    1952 Champion 2Dr. Sedan
    1953 Champion Starlight
    1953 Commander Starliner
    1953 2R5
    1956 Golden Hawk Jet Streak
    1957 Silver Hawk
    1957 3E5 Pick-Up
    1959 Silver Hawk
    1961 Hawk
    1962 Cruiser 4 speed
    1963 Daytona Convertible
    1964 Daytona R2 4 speed
    1965 Cruiser
    1970 Avanti
    You have the lines switched at the power cylinder connection. Change them and it will be normal.
      That is correct Kenny, the Left Turn and Right Turn Hoses are swapped. Can you say: "Did I do that"?
        ... making mental note never to do this ...
          Yep! That was it. Situation normal now. Thanks!
          1953 2R5
          1957 Silver Hawk
          1957 3E5 Pick-Up
          1959 Silver Hawk
          1961 Hawk
          1965 Cruiser
          1970 Avanti
            I have the same set up that I am putting on a 60 Lark Convert. Its apart and was wondering if there is a way to determine which hose goes where. The main hoses off the pump unit are obvious to me but not the other 2. Does not seem to be covered in the shop manual. Can anyone help? Thanks in advance.
            Bob
            Bob
            Welland Ontario
            60 Lark Convertible
            64 Daytona
              I was certain I had figured out and installed the hoses correctly until I touched the steering wheel. It is an eye opener, but Bob, I can say for certain how to know.(Obviously)
              Ron Dame
              '63 Champ
                Thanks for your thoughts Ron. If I get it wrong , I will now know how it will behave and how to fix it.
                Bob
                Bob
                Welland Ontario
                60 Lark Convertible
                64 Daytona
