So back in 1997 I packed the rear bearings. Since then the car has traveled not quite 25K miles...as you can see the car is not utilized all that much. Now when Studebaker called for the bearings to be re-packed the bearing grease was different then today and in 1997. Do you think I can go a bit longer without another tear down? I have no issues with the bearings, and there is no unusual noises coming from the rear end.
1964 Avanti..single leg
Tags: None
Originally posted by Hawklover View PostSo back in 1997 I packed the rear bearings. Since then the car has traveled not quite 25K miles...as you can see the car is not utilized all that much. Now when Studebaker called for the bearings to be re-packed the bearing grease was different then today and in 1997. Do you think I can go a bit longer without another tear down? I have no issues with the bearings, and there is no unusual noises coming from the rear end.You are blessed with the mental acuity to recall that you packed the bearings 24 years ago?
Wow!
Say a prayer of thanksgiving and praise and then get busy doing it again, while you are thinking about it so that you don't get rusty and lose the skill.
Fantastic!!!You are blessed with the mental acuity to recall that you packed the bearings 24 years ago?
Wow!
Just pack them again, and you will be good for another 25 years and 25K miles......................
By then, you probably won't be able to get gas to drive the car anywaythanks to our government, so this will be the last rear axle bearing repack ever (unless you convert the car to electric).
NOTE: Non-politically correct wording/phrases were automatically deleted.
- 1 like
I have always kept a grease zerk in a special place for greasing the rear axle bearings. I never leave it in. It is in a very vulnerable place to be snapped of from road debris. Besides, back in the day, it would be too tempting for a service station tech (remember those?) to pump several shots of grease in them just because they are there. In today's world, with the employees I have seen wielding grease guns at shops...you can't depend on them to lube the zerks they should and certainly not ignore the ones they should!
It won't take too many extra pumps of grease into that area until you are pushing beyond the grease seal and greasing up your rear brakes... a bad idea. Before I ever shoot grease into the rear axle bearing, I always take the time to locate and clean the tiny Weep hole in the axle (I use a dental pick). When a little worm of grease begins to emerge from that hole, you're done. Just remove the zerk, replace the plug, and you are good for a few more years.John Clary
Originally posted by jclary View PostI have always kept a grease zerk in a special place for greasing the rear axle bearings. I never leave it in. It is in a very vulnerable place to be snapped of from road debris. Besides, back in the day, it would be too tempting for a service station tech (remember those?) to pump several shots of grease in them just because they are there. In today's world, with the employees I have seen wielding grease guns at shops...you can't depend on them to lube the zerks they should and certainly not ignore the ones they should!
What model of car are you referring to?
Until I got a collection of old dental tools, I used a small paper clip wire to clean it. I have always worried that failing to clean it would cause excess grease to get by the seal and into the brake components. I have read that the fittings were not present on later models. The newest Studebaker I ever owned was a '62 GT Hawk and I don't recall if it had the accessible Zerk fitting.John Clary
I’m familiar with the axle tube vent which is up top & typically covered by the spring clip that holds down the hard brake line.
Are you saying there are also weep holes where the axle tube swells to accommodate the rear axle bearings?
Originally posted by skyway View PostI’m familiar with the axle tube vent which is up top & typically covered by the spring clip that holds down the hard brake line.
I do know the weep holes are up top, and as far as I know only one near the bearing on each end of the axles. If the clip covers them then that's a plus. But, as old as these cars are getting, people making up their own brake lines, years of maintenance & neglect...whether the clips are in their original place is always suspect. We have some members who make their living as a mechanic. My formal mechanic days was when I was in the USAF working on equipment used to make aircraft fly. The bulk of my automotive experience has been in my backyard and truly hanging stuff off the shade tree. So, anyone taking my advice should always refer to their manuals, someone they trust, and the actual parts in their greasy hands.John Clary
Wow!
Thanks in advance:-)
