53 Commander C Coupe rear fold out window
  • Body / Glass: 53 Commander C Coupe rear fold out window
    Does anyone have any tips on replacing the glass in the rear quarter window. Chrome frame. Also any tips on replacing the pins in the latch assembly.
    Thanks
    Assume you are talking about the stainless steel frame, not chrome.
    There is no way to replace that glass without complete disassembly. The stainless frame needs to be split at its seam, and quite probably reassembled with a new rubber seal and new rivets.
    '33 Rockne 10,
    '51 Commander Starlight,
    '56 Sky Hawk
      Mine is chrome. I really do understand the basics. The problem is getting the glass back in the frame as it is not very flexible . The frame is on the bench with the new glass and rubber.
        These may help I hope.............
ID:	1886085Click image for larger version
ID:	1886086 Click to expand
        AL SORAN RACING
          Thank you. That will help. Where did you find this?
            This was the hardest job to do on my '53. If you can avoid it, don't do it.
            '53 Commander
            Art Morrison chassis
            LS6 ASA/4L60E
              GREAT Service Bulletin Dwain, thanks for Posting it!
                I removed my vent window in my 54 sedan by firstly applying some solvent around the rubber, I don't know the specific solvent but there are several on the market, toluene, MEK etc.. I then started with a small wood wedge between the glass and the frame gently tapping until the glass starts to separate from the frame. As the glass and frame start to separate additional small wedges are inserted between the frame and glass. The frame will open about 1/2 - 3/4 inch then start to pull on the glass until it will release. Mine were in for 60 plus years and the both came out with this method, insertion was just a push in with a small amount of trim cement.
                  The reproduction rubber that I purchased to replace the glass was not the same configuration, and yes I'd agree it is a miserable job. I'd use urethane in a tube the next time. but then I can be a fabricobbler
                    Wish I could avoid it but it is apart now. Not only that but I can't find the rivets for the locking mechanism which I took apart for chroming. Are you using the Art Morrison chassis ? If I were to do it again that is the way I would go.
                      Don't know how you could without making a heck of a mess. I had thought about that but don't see how with the glass being so hard to get into the frame.
                        You are correct. I used urethane to set the glass in a 49 Ford windwing that I had to modify because the roof had a 3 inch chop, I wish you the best of luck, too bad the repro rubber is not "right" I've still got the repro rubber that I didn't use.
                          I've got 4 pieces that I wrecked trying to put them in
