I've added a (rebuilt) hydrovac brake booster to the front Turner discs on my '58 Champion sedan. A booster meant for car applications; not trucks, BTW. Bled the two valves on the unit and at the wheels until bubble-free before starting the car. I now have an easier pedal for stopping but it feels like the unit doesn't completely release the pads. I don't like the drag I'm feeling and, of course, a hydrovac isn't adjustable. Should I have a check valve on my vacuum line to the unit? Hate to think of gas fumes getting in there...
Check valve?
Tom
Did you get a drum brake booster? or disc brake booster? There is a check valve inside the booster somewhere, that is different for disc and drum.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
- 1 like
I am wondering Tom, what Master Cylinder you may have, I know it would be under the Floor on a '58 Champion Sedan, so if the Front Circuit has a Residual Valve in the Port of a dual M/C, or all 4 wheels are controlled by one if a Single M/C, you do not want that because the Calipers will lock up.StudeRich
Rich - I'm using an O'Reilly Brake Best (remanufactured) #10-1292 dual master, and as I recall, the 2-pound check valve for the front discs and 10-pound valve for the rear drums. Think I should remove the in-line check valve to the discs and see if it makes a difference?
Originally posted by tomnoller View PostRich - I'm using an O'Reilly Brake Best (remanufactured) #10-1292 dual master, and as I recall, the 2-pound check valve for the front discs and 10-pound valve for the rear drums. Think I should remove the in-line check valve to the discs and see if it makes a difference?
I would think it matters whether you plumbed the Hydravac to the Front Brakes or All somehow.StudeRich
