Ignition Switch loose
  • Ignition: Ignition Switch loose
    The ignition switch is loose in my 1954 Studebaker Pickup - 3/4 Ton which has as Lark dashboard. Could it be the small chrome bezzle with "J-slots" that connect the switch to the dashboard? Are the ears on the j-slots damaged as has happened a couple of years ago? Tried to upload photos with no success. Many thanks for any advice
    Sounds like it. Why not just remove it and have a look?
      It's a good idea to disconnect the battery before you do any work on the ignition switch. You won't have to worry about shorting things out if you contact metal somewhere.
        Don't get too frisky with the wiring. If you bend/flex it, the insulation will probably crumble.
        60V-L6 - 60 Lark convertible
          Yes! If not, it will totally crap out, and in the darnedest places,like in a self-serve car wash or in heavy traffic. (This happened to me. Oh yes, and once leaving a car show.)
            Good idea. Any notion where I can find a replacement?
              What Year is your "Lark Dashboard" that the ignition Switch Bezel needs to fit?
                I believe it's a 1956 and am trying to load a photo
                  The Lark came out in Sept. 1958 for the Year Model 1959.
Name:	Hawaaian Green Hardtop3.jpg
                    Update: replaced with a new bezel, spring & washer (washer didn’t formally exist). Works perfectly. Thanks all for the good advice.
