I want to retard my timing a bit, but the vacuum canister is hitting the generator (OHV6) so I want to move the plug wires on the cap and adjust from there... but which way do I move them? My mind won't wrap around this today.
My mind can't fathom this today
First figure if you hit the generator going Clockwise from the bottom up, or going Counterclockwise from the Top Down with the Vacuum Advance.
I believe it would be the Later, but I am not there. Also remember that the Rotor turns COUNTERCLOCKWISE.StudeRich
- Likes 1
I assume you want to shift the wires one position on the distributor cap so that you can move the dist. away from the generator. Whichever way you rotate the dist. (to gain clearance) rotate the wires the other direction. Just keep the rotor pointing approximately straight forward when #1 cylinder comes up to fire.
-DwightLast edited by Dwight FitzSimons; 03-07-2021, 01:46 PM.
Sorry, but that works perfectly Jeff on a V8, but will not on a Six, because the Distributor only goes into the Oil Pump, not Cam "ON Time" or 180 Out.
On a Six the CORRECT way to fix this if the Wires ARE in the Cap in the "Manual suggested Rotion" and will not Time, is to remove the Camshaft, Remove the Oil Pump, Clock the Dist./Oil Pump Drive Gear and re-install the Cam & Oil Pump. Which means you tear the whole front end of the engine apart as well.
The "Easy" Fix is what Ron is trying to do, and WILL work.StudeRich
- Likes 2
The problem with the additional slot is that it really does not help when the vacuum can is hitting the generator. If I had clearance, this could be useful.
Now that I've had coffee, I think I get it: I need to turn the distributor clockwise to get clearance, therefore I move the wires 1 place counter-clockwise to compensate. Correct?Ron Dame
'63 Champ
Originally posted by Ron Dame View PostThe problem with the additional slot is that it really does not help when the vacuum can is hitting the generator. If I had clearance, this could be useful.
Some previous owner may have installed the dist. one tooth off. Studebaker wouldn't have built them such that you couldn't adjust the timing that little bit.
-Dwight
Originally posted by Dwight FitzSimons View Post
Yep. You will be advancing the timing by moving the dist. CW, so you will compensate for that by moving the wires one space CCW.
-DwightRon Dame
'63 Champ
I got it together and tried it today. Long story short, this engine did not like any less advance, yet 3-5 degrees more results in pinging. I'll try and find my old post about engine vacuum on this thing, and append it. I'm thinking the valve timing is off.Ron Dame
'63 Champ
Originally posted by doofus View PostRon, you can check valve timing without taking anything apart. the manual tells how.Luck Doofus
Ron Dame
'63 Champ
Really??? A "Performance" 3/4 Race Street Cam, re-grind for an OHV SIX? That must be really OLD!
Yes the Cam Grinders usually knew what to set the Valve Clearance at, usually quite a bit tighter than a Stock Factory Cam setting.
FYI, the Stock adjustment is .023 to .025 Cold on Both or .025 to .027 Hot, the same as a V8.Last edited by StudeRich; 03-10-2021, 04:20 PM.StudeRich
