Hoping someone can help with identifying my 4 speed so I can order the correct parts for a rebuild. I'm confused with the wide ratio vs close ratio subject. Reading on the forum, close ratio 1 st gear should be 2.20 and wide ratio 1 st gear should be 2.54. My cluster 1st gear count is 17 and 1st gear is 36. that work out to about 2.12 (close ratio?) The numbers on the case T-10-1B Q1 K.18.61 assuming this is a 61 gearbox? the input shaft is 10 spline & the output shaft is 16 spline. The total cluster gear counts are 17-20-23-and30. Before I put allot of effort into this I would like to know if its correct for my car. The rest of the driveline is a 289 and a 3:54 TT rear.
Thanks for any help, Mark
I believe this is the chevy bolt pattern. Looks like 1 ring on the input shaft But I have only 10 input shaft spline count unless I"m counting wrong. Just counting the high spots not the grooves or slots. My clutch disc fits.
