Yesterday after installing all ignition parts I tried to crank my lark, the engine spun over a few times and then seemed to lock up, I tried it again and the same result , I put a pull handle on the crankshaft nut and it would turn easy, but felt as if rough or binding, the car had been sitting about 11 years before I put ignition parts in it , before doing so I removed the starter and could move the flywheel with a pry bar, I also put PB blaster in the spark plug holes and let it set a couple days , I reinstalled the starter and the engine spun smoothly without the spark plugs and also after the plugs were installed.
Can’t believe it would all of a sudden have a major failure, any ideas
