1961 lark 259 ignition parts
  • Ignition: 1961 lark 259 ignition parts
    Hello All
    trying to get my Lark 259 ci going anyone have any current part no. For conventional , points condenser and rotor button
    thanks
    herb
    Why not just order from one of our vendors? Studebaker Int'l, Stephen Allen's, and others should have the proper parts.
      You will do yourself a big favor if you order the chassis parts catalog and the body parts catalog. They show almost every part, where it goes, how it interacts with other parts, the "official" name of that part and the part number.
      We in Studebaker land are very lucky to have such great parts catalogs.
      60V-L6 - 60 Lark convertible
        Just thought Napa Auto parts might carry them, wanted to try and get it running this week , if no luck at Napa tomorrow I will contact Steve, also if the engine runs good may change it to electronic ignition, comments welcome
          Just tell them it is a 1960 Chev. 283 V8, IF you can see that it STILL has the Original Delco Window Distributor with the little Tin Door to adjust the Points with a Allan Wrench.
            NAPA used to look up parts using the distributor part number.
              Doesn’t have the Delco dist, think it may have a prestolite , it has a small set of points not the ones you can use an Allan wrench to adjust
                OK, that leaves a single point Prestolite from a '62 to '64 Stude. or an Early Delco from a '51 to '59 V8.
                The ROTOR Shape is always the easiest way to I.D. these Three Types.
                The Prestolite uses a very Flat Dog Bone Shaped Rotor.
                Click image for larger version  Name:	Early Delco.JPG Views:	0 Size:	27.9 KB ID:	1870140 Click image for larger version  Name:	Early Delco2.JPG Views:	0 Size:	48.0 KB ID:	1870151
                This is the Early Delco Rotor.
                For you "Perfectionists" that will say I missed one:
                Of course I am ignoring the super rare possibility of a Prestolite Dual Point Avanti/Jet Thrust R1 or R2 Dist. because that would have been Obvious by now.
                  Maybe this will help.
                  https://northstarstudebakers.com/wp-...nterchange.pdf
                  '33 Rockne 10,
                  '51 Commander Starlight,
                  '56 Sky Hawk
                    That Chart is good for "some" Parts Brad, not so much Ignition. Unfortunately not all Stores sell "Standard".
                    Looks like someone did not research the easiest to find Part Numbers for Ignition Parts on that chart.
                    I see nothing for "NAPA" Brand, and few on their Brand "Echlin".
                    Either way the Distributor still needs to be identified.
                      Thanks for the info guys ,my rotor looks some what like this
                        ‘62 - ‘64 Prestolite without question.
                          Got all my ignition parts at Napa , yahoo, it may be running by tomorrow !
                            I haven't bought any ignition parts at NAPA lately. Do the boxes state the country of origin?
                            jack vines
                              Mr. Nagel spent a bit of time putting together the spreadsheet when he was active in the Studebaker hobby, but it's been over ten years since he moved on to other endeavors.
                              It would be nice if someone could pick up where he left off and fill in more of the blanks.
                              '33 Rockne 10,
                              '56 Sky Hawk
