thermostat from rock auto is too small and so is autozone 289 full flow swap to a 60V lark
OH MY GOSH! WHAT is that thing in Pic #4! The "Stat" next to your Thermostat Housing, it must be for some other make?
For next time just so you know, the Stat gets Sealant & goes into the Stat. Housing in the groove First, then the Gasket over it, THEN on the Manifold, that seals the Stat from leaking internally and prevents getting it off center. That is what the Recess is for in the housing.
Ignore this if you got that, I can't tell from only the Pics how you proceeded. Picture 1 looks like you put it in the Manifold.
It will probably be just Fine.StudeRich
Originally posted by StudeRich View PostOH MY GOSH! WHAT is that thing in Pic #4! The "Stat" next to your Thermostat Housing, it must be for some other make?
i had it reversed, the manifold was filled with coolant and i didn't want my paper to get soaked so i blocked the water with the stat, gooped it up and paper after, and gooped the housing and dropped that on top,
i hope i centered it, i cut the papers round too small , so it actually presses against the stat on it's circumference, didn't want to trim and trim and trim
so if it's off centered the paper with goop with stop internal bleeding.....i screwed up whatever lolLast edited by mw2013; 12-13-2020, 06:31 PM.
