I found a cheap wheel that will fit a 50 4-lug! (well sort of)
  • Wheels / Tires: I found a cheap wheel that will fit a 50 4-lug! (well sort of)
    I've been doing a lot of searching to find a wheel to fit my 50 Champion, and there seems to be much confusion about what will work. It has 4 in spacing, which kind of hard to find unless you're looking at trailer wheels I happened to have 90 14 in Honda Civic wheel that I had lying around, and it works! Mind ypu it's not perfect, the Civic wheel has a 100 mm spacing which converts to 3.937 inches but it should work for a spare or to roll the car and no way for regular driving!!!! These wheels can be found on Civics (later models came with 4.5 in), VWs , and Miatas. Just a though use them at your own risk!!!!
    There were also 4 lug wheels on some of the smaller engine Ford Fairmont cars from the late 70's. Probably not a lot of them in the bone yards, though.
    60V-L6 - 60 Lark convertible
      Those wheels are 108m (4 1/4") bolt circle Roy. Same as the Pinto and Mustang II. The earlier Mustang, Falcon and Maverick had a 4 1/2" bolt circle, same as Datsun. I believe you 're looking for a 4x4" pattern? It was common to CROSLEY, AUSTIN HEALEY, JENSEN-HEALY and MG. Kawasaki and Polaris also use it on their off road vehicles.
        That's interesting. Maybe I was thinking about Nash Rambler replacement wheels, that are the same as some early Jeeps.
          Don't front wheel drive vehicles have a different offset? A quick check list Jensen Healy and Sprite, but maybe not 14"
          https://www.roadkillcustoms.com/whee...4x4.00-inches/
            Yes, FWD cars have a positive offset (centerline of rim is inboard of the mounting plane at the hub).
            Best example are those goofy Toronado rims....
              Every time I see either the Toronado rims or VW Bug rims, I think of my days in a gas station using a Coats 10-10 machine with the special adaptors for them. Flip it one way, it's for VW, the other way, Toronado. The Coats 10-10 was not kind to Cragar mags though. DAMHIK.
                Yes, but they very, the Honda wheels is not too much, so it works fine.
                  Topper, the first Cragar mags I ever had were some I got from a gas station that had a big chip out of the center where they had broke them on their tire changing machine. They were really cheap & I figured I could over look the chunk missing from the center until I could afford better wheels.
                    Mike, that's exactly what happened.
