width, diameter, bolt circle and back space, thank you
what is exact dimesions and the stock backspace for a 60 lark 2 dr v8 wheel
Tags: None
The first three are very easy, the 4th. would take a measure, because "About" doesn't work.
4 1/2 Inches Wide inside the bead.
15 Inches Dia.
5 on 4 1/2 Inches Standard Ford/Chrysler Pattern.
Backspace: TBD.
________________________________________________________________________________ ____________
3/4 Inch Hex Lug Nuts, that do not work on other make Wheels that use 11/16", easy fix.
3 Humps Moulded into the wheel "Center" that hold the Studebaker only sized, small Hubcaps when the Optional Wheel Covers are not used.
- 1 like
Originally posted by mw2013 View Postwidth, diameter, bolt circle and back space, thank you
i don't understand the lug nuts comments, you say stude 3/4 and others are 11/16 and they are interchangeable?
I think Rich mis-typed. Stude lug nuts have a 3/4" hex, and 1/2-20 thread. Ford lug nuts have a 13/16" hex, and 1/2-20 thread. For years, in the same era, GM cars had lug nuts with a 3/4" hex, and a 7/16" fine thread. Chrysler products generally similar to Studebaker.
If you put Ford rims on a Studebaker, you should also use Ford lug nuts, as the taper seats in the Ford rims are designed for the larger nuts.Gord Richmond, within Weasel range of the Alberta Badlands
- 1 like
UPDATE: OK back to the Real, IMPORTANT Original Question: What IS the Wheel Backspace?
15 Inches Dia.
5 on 4 1/2 Inches, Standard Ford/Chrysler Pattern.
Backspace: Measured from the outside of the Inner Rim Surface to the Drum Mounting Surface of an Original '59 Lark Wheel = 2 3/8 Inches.
Keep in mind that these Wheels are for the Stock Drum Brakes, and will not have enough clearance for Disc Brake Conversions.
3/4 Inch Hex Lug Nuts, that do not work on other make Wheels that use 13/16" WRENCH Size, Also 1/2 -20 I.D. as apposed to the Stude. 3/4" Wrench Size and different Seat Angles, an easy fix.
3 Humps Molded into the wheel "Center" that hold the Studebaker only sized, small Hubcaps when the Optional Wheel Covers are not used.
Originally posted by StudeRich View PostUPDATE: OK back to the Real, IMPORTANT Original Question: What IS the Wheel Backspace?
15 Inches Dia.
3 Humps Molded into the wheel "Center" that hold the Studebaker only sized, small Hubcaps when the Optional Wheel Covers are not used.Last edited by mw2013; 10-24-2020, 01:57 PM.
mw2013 , in future please add a Prefix to posts in the Tech Talk section. I did it for you this time. Thanks.
Originally posted by StudeRich View Post4 Inches could possibly mean interference with the Suspension Components, Tie Rods, "A" Arms.
The OP should take one of his 15" wheels, put it on the front (4" should work on the back) and extend it back to 4" by adding a cardboard ring around the inside of the rim and see what happens. 17's are tight on the front of an Avanti, basically same parts, at a 4 1/4" BS except Disc Brakes. The interference comes from the suspension.
Just check before you buy.
Bob
- 1 like
There will be a range of backspacings that will work fine. Studebaker probably picked the middle of that range for their OEM wheels. But the original wheels don't have enough to accommodate some disc brake conversions, so different wheels with a bit more BS are required. If you reduced the backspacing to zero (like reversing the wheels) you run the risk of having the tires rub up against the fender lip. If you make it too big, the tires may rub against the suspension. If you want to replace the OEM wheels, get some that are close to the OEM measurement.Skip Lackie
Originally posted by Skip Lackie View PostThere will be a range of backspacings that will work fine. Studebaker probably picked the middle of that range for their OEM wheels. But the original wheels don't have enough to accommodate some disc brake conversions, so different wheels with a bit more BS are required. If you reduced the backspacing to zero (like reversing the wheels) you run the risk of having the tires rub up against the fender lip. If you make it too big, the tires may rub against the suspension. If you want to replace the OEM wheels, get some that are close to the OEM measurement.
stock 4.5 wide wheels are weak and narrow, does that me they are worthless and goes in the trash?Last edited by mw2013; 10-26-2020, 05:18 AM.
The stock wheels were perfectly adequate for the cars that Studebaker was building 60 years ago, and were not really weak when compared to other contemporary wheels. . But the tire industry has changed the aspect ratio 2 or 3 times since then, and there are no modern equivalents to the 6.40 or 6.70 x 15 tires that Studebaker put on their cars then. The OEM wheels certainly are too narrow for the commonly available 215/75x15 radial tires, and were not designed for radials anyway. That said, some of us had good luck with mounting 195 radials on them, but that size has pretty well disappeared from the market place.
If your tires are in good shape, there will be people who will want them. Throwing away usable Stude parts is kinda frowned upon. You might even make a few bucks on the transaction.Skip Lackie
