Noises??
  • Transmission / Overdrive: Noises??
    1964 Studebaker Daytona 289 mated to a 1952 automatic transmission.
    What sound would the motor and transmission make if the transmission was not dialed into the bell housing properly or at all? I have a hunch that the gentleman that installed my motor and trans did not really do the proper work that I paid him for. This was about 2 1/2 years ago, that I got the car back from him, and I have only had about 3 or 4 hours every other weekend to work on it. But now I'm hearing things...
    Are you hearing some clanging/banging/clicking idling in neutral?
    60V-L6 - 60 Lark convertible
      Yessir I am. That is the noise I'm hearing.
        Sounds like a cracked flex plate to me. That could certainly be caused by not dialing in the bell housing.
          Is the noise at idle, or when revving the engine?
          With the DG automatics, revving the engine while not in gear is a bad idea. If I remember right, it’s something to do with the torque converter trying to lock up.
            That could just be the One way Clutch in the Lockup Torque Converter failing, as Matt said.
            That certainly IS a FIRST... a '64 Daytona 289 with a DG Detroit Gear/Studebaker Automatic Drive!
            Is it a 1955 DG-250M with Low Gear Start?
              That's not a "first."
              I put a 63 Cruiser 289 in my 1954 Commander wagon with the original 1954 DG Automatic Drive transmission when I built the car in 1992 or 1991.
              It works just fine - as fine as it ever did.
              But I am not a "spirited" driver, either.
                Noise is at idle. I did find my fluid level was really low, so I'm going to clean, drain and fill this weekend
                  It is the 1952 DG-200...
                    If it is more of a Humming/Rattling Sound, it would be Low Fluid and or Throttle Pressure out of Adjustment.
                    In a '64 Body and with a '64 Engine, the Throttle Pressure Linkage is certainly suspect, as to 1952 Trans. Compatibility.
                    Be sure to Check it at a LOW Idle and In Low Gear, any other way gets serious Splash and an incorrect reading.
                    Also remember that there is a Converter Drain Plug, usually actually two.
                      Not a first. Years ago I put 259/289 in front of DG automatics, including a S/C 289. I did prefer to use the DG250M.
