CASO heater control
  • Cool/Heat: CASO heater control
    Found coolant on the passenger floor and tracked it down to the control valve. $6 trip to the hardware store later, dry and warm (knock wood) 😁
    That's good, plus it works.
    Most people seem to use their heaters in a digital manner - either full on or completely off. They are not aware of any intermediate position.
    60V-L6 - 60 Lark convertible
      Good job. Even better if the valve has a stainless steel ball and Teflon seats.
      With a little further thought and creative fabrication (fabricobbling), you could even modify the valve handle to accept a cable so that you can adjust the water flow and heat from the dash just like the original valve.
        Very creative. Thank you for sharing. I have always been a big fan of function over form.
        Studebaker! If you're lucky enough to own one, you're lucky enough!!!
          My dad used the same valve in his '53, thirty years ago. He mounted it so he could attach the stock cable to opperate it, been working fine ever since. In my GT I used a Ford/GM/Chrysler inline valve that is meant to be cable controled and used the stock cable to work it. My stock valve worked fine but it's bulky and was in the way of moving my battery to the right side. The valve I used looks like this:
          Here's one on ebay: https://www.ebay.com/itm/Car-Auto-He....c100005.m1851
            That's great, but you need one that is "Pull to Open", not Close and for 1959 and Newer Studes. it needs to accept 3/4" Hose In and Out.
            Otherwise for '47 to '58 you need one to accept small 5/8" Hose.
            Usually it is hard to find a seller that will tell you ANYTHING that Matters, about their offshore product.
              Mill Supply has valves that either push or pull to close, and fit 5/8" hose. These were used in most of the step vans prior to electric controlled valves.
              https://www.millsupply.com/cable-ope...3.php?p=324877
              '33 Rockne 10,
              '51 Commander Starlight,
              '56 Sky Hawk
                That could be a better Valve than the thin sheet steel on the one in Post #5, But due to the dark Black Color it's hard to tell what it is made of, it looks like it COULD be Cast!
                I never heard of "Mill Supply", they have some Good Stuff!
                Isn't that always the way with Auto Parts Websites nowadays, they list EVERY Brand of Car including Obscure, Obsolete makes Like; Saturn, Plymouth, Mercury, Pontiac, Oldsmobile and 1732 Ford Parts, but NO Studebaker!
                  The Mill supply valve looks like composite to me. May not be a bad thing though, when it comes to corrosion.
                    Took the car out for breakfast this morning. The wife liked the heater under her seat😁
                    This is a Band-Aid until I get around to fixing the original. I don’t want to drive around with a two inch hole in the firewall this winter. I found this site for DIY repair:
                    https://studebaker-info.org/Tech/Ran...b/rancotb.html
                      To anyone who has managed a fleet of step vans, the Mill Supply catalog is a bible.
                      '33 Rockne 10,
                      '56 Sky Hawk
                        But when they do list Studebaker, they get often/usually it wrong, so.... what is worse?
                          That Ebay listing I posted was just for reference, it's not the actual one I used. The one I used is 5/8" in and out and does function in the correct direction. My '62 uses 5/8" heater hoses.
                            I believe that our own SDC member vendors do such a great job of supporting our parts needs that it discourages the average " Big-Three" focused market from jumping into the Studebaker parts business.
                            Those that do offer Studebaker parts are usually very narrowly focused on items that cross-reference and apply to multiple makes industry-wide. (And as Roy states, they often get it wrong and have the application cataloged wrong.) So, I believe it is in our collective interest to support our SDC vendors when it makes sense. I still buy from local flaps for convenience items like points, spark plugs, etc., when readily available and priced reasonable.
                              I like the looks of the one you used. It looks compact, and simple. I don't know if it has a ball & seat internal construction or a simple gate valve? However, it looks to be only 1/4 turn actuated, comes with a stationary connect point for the cable sheath (so you don't have to engineer one) and that puts you way ahead of the game giving you the opportunity to use your factory stock cable.
