Fulton Exterior Sun Visors
  • Fulton Exterior Sun Visors
    Hi Guys. I just acquired a Fulton sunvisor for my 49 Champion coupe. It came off of a 51 coupe. Since there is no center windshield support, the visor has a large plate that attaches to the roof for the center support. I am about to install, but I hesitate after I saw a query and answers on SDC Forum that mention much higher wind noise and some flutter at higher speeds. Since the item requires four screws on the roof for the support plate I would hate to fully install and then find out that I should not have drilled them! Or worse if the thing tries to blow off.
    Does anyone out there have a Fulton on his Stude or know more than I do about them? If so how do you like it? Any recommended modifications? Any installation tips? Oh yeah, where do the two small cap nuts go? They were left over after I assembled it.
    Thanks much for your help.
    I can't answer your questions, but this guy recently put one on his 52 Land Cruiser (if you do facebook).
    https://www.facebook.com/permalink.p...90473897976584
    3H-C5 "The Blue Goose"
      I put a Comet (Fulton competitor) on my 1950 Commander starlight some 40 years ago.
      Instead of the roof mounted plate, I used a polished aluminum tube from the center of the visor down to the cowl, that required a small bracket from a wrecking yard that basically attached to the cowl with horizontal screws, through the cowl, just behind the hood. Such a bracket could easily be made from thin sheet metal.
      The resulting vertical tube was not distracting and was mechanically much stronger than the center roof bracket. There was no fluttering/flapping/flopping/noise from the visor.
      60V-L6 - 60 Lark convertible
        You might want to check out Big Jim's out in Texas.
        https://bjsfenderskirts.com/
        They have been doing visors and fender skirts for decades...
        Good source for info and parts.
        HTIH (Hope the Info Helps)
          Is the Fulton visor a single piece, or two piece visor?
          If it is a two piece visor it will definitely need either a wide roof bracket such as seen on the '52 Land Cruiser above, or a center support rod extending to the cowl.
          If it is a one-piece visor a bracket like those originally installed on Studebakers would suffice.
          '33 Rockne 10,
          '51 Commander Starlight,
          '56 Sky Hawk
            Click image for larger version  Name:	DF6F0FDF-BDBA-4474-BA7B-773D599EC8B2.jpg Views:	0 Size:	13.8 KB ID:	1861068
            That's pretty close to what I did. It all started by finding that tiny bracket on the cowl. It was on a car in the wrecking yard.
