Relay versus Solenoid
  • Transmission / Overdrive: Relay versus Solenoid
    What we commonly refer to as a solenoid is in reality a relay. A relay is an electromagnetic device in which a weak current acts as a switch for a stronger current. You will find a solenoid in a circuit breaker and in turn signal flashers. There are a variety of "relays" some are internally ground some are external ground and some are designed for continuous duty. There are 6 volt and 12 volt also some have silver contacts for much longer service life. Some are designed with an external handy push button. From time to time you hear of somebody installing a new "solenoid" and it doesn't work could be the wrong application.
    Yes and no. Usually a solenoid refers to an iron core that is pushed (or pulled) when the coils are energized. A relay usually refers to a device where a where contacts are closed when the coils are energized. Two different actions, not interchangeable.
    78 Avanti RQB 2792
    64 Avanti R1 R5408
    63 Avanti R1 R4551
    63 Avanti R1 R2281
    62 GT Hawk V15949
    56 GH 6032504
    56 GH 6032588
    55 Speedster 7160047
    55 Speedster 7165279
      Altair might be talking about the starter solenoid that sends power to the starter when the button is pressed or the key is turned.
      Interestingly, although we call it a solenoid, it actually is a relay. I never thought about it like that before.
      60V-L6 - 60 Lark convertible
        In electrical theory, "solenoid" is any long cylindrical coil. The familiar Studebaker starter solenoid is, internally, a solenoid coil with a moving plunger which moves a copper disc to bridge two or more contacts. You could call it a relay, or a magnetic switch, too.
        Starter solenoids on many Brand X cars use the solenoid plunger to engage the starter pinion with the ring gear, as well as moving a copper disc to bridge several contacts.
        Other uses for solenoids? Power door locks, power trunk release. Less so on modern cars, as a tiny motor working through a gear train is more reliable, and weighs less. And uses less expensive copper wire.
          I was also commenting that these relays have various applications and various wiring configurations. I went in to an RV store and I was looking for a continuous duty relay and the attendant did not know. There was a bin full of bulk relays and he said this is what we sell. This is the type that when actuated with the key will deliver a charge to the RV battery however when the key is off the relay is open and will not discharge the engine battery, A conventional relay will work but the life is shortened. How many times have you seen big RVs with their battery assembly out on the ground trying to find a problem. It could be as simple as a continuous duty relay.
            I agree . However, checking the truck parts book Studebaker actually called it: "SWITCH, starter (magnetic). Seems like that covers it pretty well!
              Don't forget too, that many relays have both a normally open and a normally closed pair of contacts and switch between them. Solenoids usually only work in one direction or opperate as a slave to control a mechanical function. Relays are typicaly used for higher power switching so a low power (smaller) switch can be used to trigger the relay. Solenoids are typically used in an opperational aspect.
                ...and HVAC techs will often refer to hi-load relays as “contactors”.
                "potayto, potahto, tomayto, tomahto, ...let’s call the whole thing off?"
                  That's right. When I was a pup repairing hospital X-ray machines, the huge relay that energized the primary of the high tension transformer was called a contactor. And the transformer was called high tension, rather than high voltage. It was 180 KV.
                  Boy, that was a fun job for a 21 year old just out of technical school and just moved away from home. With a brand new 71 Plymouth Fury III coupe as a company car, too.
