OD troubleshooting
  • Transmission / Overdrive: OD troubleshooting
    So need some help here...48 champion..new solenoid and new relay switch and OD still doesn't work. No idea what to do next. Any thoughts on which direction to look next?
    With all due respect and and without trying to lecture, do you have a shop manual? There is a very easy to use diagnostic procedure in the shop manual.
    Skip Lackie
      https://talk.classicparts.com/attach...ual-pdf.23794/
      Free issue of the OEM manual for the R-10 and R-11 systems used by all makers in the day. Absolutely essential reading.
      The mechanical and electrical sections give further proof of American automotive engineering genius.
        Several suggestions on your previous post: https://forum.studebakerdriversclub....roubleshooting
        3H-C5 "The Blue Goose"
          There is Much more help on your original String.
          All of your Posts and Strings can be found by clicking your Name then, "About", then "Links" all the way to the Bottom, then "All Posts" or "Started Posts".
