Water pumps (pics)
  • jclary
  • 64V-K7
    Actually it was on the car when I got it. The recovery system is not pressurized, as there's an overflow dump at the filler neck. The hose from the radiator enters at the bottom of the white tank.
    The overflow bottle and the motorized windshield washer tank on the other side were nice touches.
    Bob Johnstone
    www.studebaker-info.org
    64 GT Hawk
    55 President State Sedan
    70 Avanti (R3)
    Bob that is an interesting coolant overflow recovery tank, I have never seen a pressurized one, wouldn't the second pressure cap fight the first one unless they were perfectly matched to less than a pound?
    Where did you find such an unusual piece?
    quote:Originally posted by 55Prez
    Pics of my 64 GT with factory air.
  • ivorydan
    Thanks, Bob! Dan
  • 64V-K7
    I'll get a pic this afternoon. The prop rod is a different part number on cars with A/C. It's either longer or shorter, as the hole for it, on the top rad support is blocked. I had to make some changes when I got to that part of the reassembly...
    (1 hour later)...
    The pics show the situation. If you try and use the prop rod in the original hole, it can't lay down enough to get to the clip because it's blocked by the condenser .
    I drilled another hole above it a couple inches and this works fine. The different rod called in tha Parts manual, might have a dogleg in it.
    <P>
    Bob Johnstone
    64 GT Hawk
    70 Avanti (R3)
  • ivorydan
    Hey Bob:
    can you print a picture of your condensor and prop rod? I'd like to see how it compares to mine. Thanks! Dan
  • Stude8
    It's been 18years since I built and installed A/C on my 7E7 62 T cab truck. I learned at that time Studebaker produced FOUR different V8 water manifolds! There are different water pump flange spacing distances between the manifold and radiator among them.
    You have to consider this spacing distance in your water pump selection process.
    At this date God only knows who switched what parts on your vehicle over its 40 or 50 year life span.
    Parts books say this:
    0505-34 1555739 Water manifold AVANTI RQ engine
    0505-34 1557961 Water manifold JT equipment 1963-64
    0505-34 1548349 Water manifold 1959-60 V8 passenger car
    0505-34 1551031 Water manifold 1961-64 V8 passenger car
    Stude8
    1928 Commander GB
  • Chucks Stude
    Now it all makes sense. I guess the fast and nasty way to do A/C was to chop the shroud off. They did not bother to put a bigger fan in either. Thanks for all the help. You all are the best.
  • 64V-K7
    Pics of my 64 GT with factory air. Six blade fan. No viscous coupler yet. L o n g shroud with overhang on top. Almost looks like a 6 cylinder shroud with a hunk cut out of it. On the PS pic, I added a strip of tape so the outline is easy to see.
    <P>
    Bob Johnstone
    http://www.studebaker-info.org
    64 GT Hawk
    70 Avanti (R3)
  • Chucks Stude
    Please do. I used to think that all of this was fairly basic, but time has eroded a lot of my memories of how these things were back in the day...........Used to pull the engine and rebuild it in the time it has taken to write this thread.... my how things have changed.
  • 64V-K7
    I have a 64 GT Hawk with all factory A/C components. The shroud is quite long and, in fact, there's a cut out to clear the compressor clutch. I use a 6 blade fan without a viscous coupler and it is noisy, but there are no cooling problems.
    I'll take some pics tomorrow..
    Bob Johnstone
    64 GT Hawk
    70 Avanti (R3)
  • ivorydan
    Chuck, here's a picture of my 64 R1 Hawk. It came with heavy duty cooling. The same setup was used on factory AC. The shroud and blades look the same to me as yours. The original fan was a five blade silicone setup. If I recall, they used a fixed six blade fan for extra cooling in years prior to the development of the silicone (viscous) setup.
    Looks like my blades are about where yours are. I used to see mechanics cut a notch out of the longer non AC shrouds when some sort of after market AC was added in order to clear the compressor
  • jimmijim8
    Chuck, here's what I think. I don't think that your Hawk came from the factory equipped with an AC unit and/or if the dealer or whoever installed the unit on the car, well, it was done improperly. I base my statements on the fact that my car is AC factory equipped. Factory equipped 63 Hawks cars came with a fan clutch and a 6 bladed fan 18" diameter. I don't know what year your car is but your engine is likely to be a 60-62 based on your oil fill and valve covers. You are correct in thinking that your fan does not project into the shroud far enough. On an AC equipped Hawk using the York compressor, the shroud had to be trimmed back a bit near the compressor only for added clearance. It looks as though someone has trimmed the entire circumpherence of your shroud. 360 degrees. Not correct. It is now not deep enough and you may cut your fingers off. Get another shroud and trim it properly. Your fan, clutch, and spacer assembly may have been out of balance causing the non heavy pump casting to fail. Maybe your belt was tightened too much or perhaps both. Let us know. jimmijim
  • Chucks Stude
    Oh, yeah, and after I use the rest of this case of 15/40, this car will use 5/30 like everything else that I own, except I will throw in a bottle of zinc with each change. Done with the thick stuff.
  • Chucks Stude
    The radiator guys are telling me that there has been a change in thinking on radiators. I have to admit that I have forgotten the specific numbers, but they are finding that a two row with wide spacing makes for more cooling than a three row with narrow spacing between the tubes. As to the fan, I gave that 5 blade fan to Allen Songer, and acquired a 6 blade, with more diameter from Dave T. It fits the shroud better, and I should have a picture, but the water pump broke. The pic of the fan is at the top of this thread, with my watch dog watching over it.
