quote:Originally posted by Chucks Stude
The car origionally came with a fixed 4-blade fan, and this spacer. The car is an airconditioned GT. That fan made a lot of noise.When I went to the viscous drive,and 6 blade fan, the fan did not stick past the edge of the fan shroud without the use of the spacer. This caused the engine to run hotter than it had. Putting the spacer back in, took care of that problem, and driving the car in 100 degree heat, stop and go, did not overheat the car. It never went over 185 degrees. When the water pump failed, it was not the bearing that failed, it was the housing. Now, I have only found numbers for two water pumps, standard 1558224,and the Avanti unit. Am I missing something? The studs are too long, and that will be taken care of. Had to use studs, because the orig. Studebaker viscous drive had holes in it not slots. Bolts would not work because they would not go around the housing of the viscous drive.
I checked the parts book to verify what I was remembering.
'63 & '64 V8 Larks used fan spacer 1539063 which is 1" thick; this spacer was [u]not</u> used with viscous fan drive equipment, per the parts book.
'63 & '64 K body (ie, GT Hawks) cars used fan spacer 1539063 also; but again, [u]not</u> used with viscous fan equipment per the parts book.
Are you sure that you have the correct fan shroud for your GT, and that it has not been cut down (shortened)? I do know that on my '64 GT with viscous fan, the blades only protrude partway into the shroud, but cools ok.
Paul
Winston-Salem, NC
Visit The NEW Studebaker Skytop Registry website at: www.studebakerskytop.com
