OD governor speed change
  • Transmission / Overdrive: OD governor speed change
    I recently swapped out the original 4.56 rear axle with a Dana44 from a 52 Commander that’s a 3.53 ratio. This makes my OD kick in late. Is their a replacement governor that kicks in faster (at a slower driven RPM) to allow the OD to engage at a speed commensurate with the slower turning transmission output shaft? (Main shaft and governor gears, or a complete governor to accomplish this?)
    If you disassemble the governor, you can probably put in a lighter spring and make it engage sooner.
    On the other hand, the overdrive is kicking in at the same engine RPM as it originally did.
      Making it shift sooner, will make it have even LESS Power and lug the Engine.
      The reason is simple, a 3.54 from a DIRECT Drive Automatic is just TOO High an Axle Ratio for the Overdrive and the Power of whatever Engine is powering it, probably Under120 HP.
      Every time you get to a Bridge a little higher than an Anthill, you will have to shift to Direct Ratio.
      If you switch it to a 4.10 Ratio Model 27 Dana, it will "Pull" just fine.
        With the 3.54 axle in overdrive you will be running the equivalent of a 2.55 ratio. I'll admit to being surprised that you want that and would suggest keeping the original cut-in rpm on the governor to give the engine a fighting chance. With the change you noted the governed speed should be 38 mph or so. I think you will need it.
