We've built a Studebaker V8 we want to hot run to check out before we ship it.
With a standard transmission build, this would be no problem, just bolt on the flywheel, bell housing and starter.
However, the automatic transmission is a different deal. The starter ring gear is on the torque converter, so there would have to be a complete automatic transmission, filled with fluid, bolted onto the back of the engine. That's a huge hassle we'd prefer to avoid. (Plus, the bell housing should be dial indicated as well.)
The crankshaft bolts used for the automatic are too short to bolt on a flywheel. I know it's possible to booger up a flywheel by countersinking the bolt holes enough so the auto bolts can be used, but not the way we'd prefer to do things; although it may come to that.
Suggestions? Ideas?
jack vines
Suggestions? Ideas?
jack vines
