Cracked block. Champ
  • Engine: Cracked block. Champ
    Pretty sure I have a cracked block. I thought bad casting, but I can feel it inside. And, the block has a slight bulge above the crack. Of course, this was the better looking block, better looking cylinder walls, no score marks, and couple thousandths smaller bore. This is the heavy duty block, the one I was going to rebuild from ground up. Beer time I guess... or cry... or maybe both......
    Mike and Dawn
    '61 Champ
    Definitely a freeze crack. It can be welded successfully, but probably not rare enough to bother.
    Proud NON-CASO
    Romans 15:13
    Deuteronomy 31:6
    Proverbs 28:1
    Illegitimi non carborundum
      Probably time to upgrade to a V8. It's a bolt in. You'll get the same gas mileage and a ton more power.
      sals54
        Even cracks that long can be stitched up via the Lock-N-Stitch method; It's just time and money. http://www.locknstitch.com/index.html
        Just for the good of the order, IIRC, any Champions designated as "heavy duty" were because of the slight differences in the internal components used; valves, rotators, chrome rings. All blocks from a given year are the same, true?
        jack vines
          jack vines
          That's pretty fancy. I have welded many over the years with a Lincoln buzz box and nickel rod. I drill a hole at the ends of the crack, v-notch, heat with a torch, then weld. It's old school, but has worked every time.
          Proud NON-CASO
          Romans 15:13
          Deuteronomy 31:6
          Proverbs 28:1
            With the size of that freeze crack, I would worry about the rest of the block. I suggest starting with a different block/engine.
              That is a V8 block out of a Champ pickup. Not a Champion six.
              I have a good “core” block that I would give you. But I’m sure you can find one closer than Florida.
                Looks to me like time for a LS swap.
                  I have another block, but its not great, taking it in next week to get checked out and cleaned. Thanks for the offer though!
                  Mike and Dawn
                  '61 Champ
                    Yeah, my thoughts too. Guessing ice pushes in all directions.....
                    Mike and Dawn
                    '61 Champ
                      jack vines
                      Interesting about the Lock-N-Stitch.
                      From what I can determine, HD engines had the same blocks, just some better engine components for better torque reliability.
                      Mike and Dawn
                      '61 Champ
                        I have another block, not as good, but guess I will being using it instead.
                        Mike and Dawn
                        '61 Champ
                          FYI...When a block freezes/cracks, it's usually the second time it freezes, that it cracks. The first time, the block will usually bulge out. When the coolant thaws and freezes again is when it will usually split...but not always...
                            Thanks for the information, I did not know that.
                            Mike and Dawn
                            '61 Champ
                              Ther is absolutely NO REASON to throw away a good block for a minor crack. I've pinned them with 100% success. It will take a couple weeks at 5 min per day . If you have never done it send me your address and I will mail you detailed instructions.
