Originally posted by RadioRoy
View Post
Radio: conversion to 12v
The memory power will drain the battery if the car is not driven at least once a week. Maybe even more often since the car is 6 volts.
I hope you don't chop up the dashboard for that butt ugly radio.
Good work! Are you going to try one? I wonder if it will switch polarity also. It almost looks like it will, but cannot be sure. For that price, it's worth a gamble.Last edited by Matt N; 09-23-2020, 08:51 AM.
I put a modern radio in my 1954 3R6 pickup (6 volt, positive ground) and used this. It converts both the voltage and the polarity, if needed. Works well. Interestingly, it is made in New Zealand.
https://www.vintageautogarage.com/6-...V-p/ce412v.htm
Originally posted by Matt N View Post
Years ago, I installed an invertor/convertor in my 1953 Commander Starliner to operate a 5 Watt CB radio. I mounted it up behind the dash and it worked fine.
Many years ago, I put a cassette player in a '54 Champion that was my daily driver, and I built an inverter that used a 1:1 turns ratio transformer, and a pair of power transistors. Basically, it stacked the input 6 volts with the output 6 volts, and put out 12 volts, positive ground. I simply isolated the cassette player from the body. Best of all, the inverter only ran if it saw a load. Quiescent, its draw was trivial. It worked just fine.
But I don't remember how it was wired. I do remember I just sort of fluked into it.
Your car is supposed to be six volt, POSITIVE ground. That's the way the factory built it.
There is only one GOOD 6 to 12 volt converter available, and that one is only available to Aurora dealers.
https://www.tech-retro.com/aurora-de...eet%201.2b.pdf
The little silver cube converter has very limited power, but can be installed by amateur mechanics.
There is one on eBay that looks good at first glance, but it will not reverse polarity.
Did a search but couldn't find much. Has anyone used a step up converter to use a modern radio on there 6v neg ground?Tags: None
