Did a search but couldn't find much. Has anyone used a step up converter to use a modern radio on there 6v neg ground?
Radio: conversion to 12v
Tags: None
Your car is supposed to be six volt, POSITIVE ground. That's the way the factory built it.
There is only one GOOD 6 to 12 volt converter available, and that one is only available to Aurora dealers.
https://www.tech-retro.com/aurora-de...eet%201.2b.pdf
The little silver cube converter has very limited power, but can be installed by amateur mechanics.
There is one on eBay that looks good at first glance, but it will not reverse polarity.
Last edited by RadioRoy; 09-22-2020, 02:01 PM.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
Many years ago, I put a cassette player in a '54 Champion that was my daily driver, and I built an inverter that used a 1:1 turns ratio transformer, and a pair of power transistors. Basically, it stacked the input 6 volts with the output 6 volts, and put out 12 volts, positive ground. I simply isolated the cassette player from the body. Best of all, the inverter only ran if it saw a load. Quiescent, its draw was trivial. It worked just fine.
But I don't remember how it was wired. I do remember I just sort of fluked into it.Gord Richmond, within Weasel range of the Alberta Badlands
Years ago, I installed an invertor/convertor in my 1953 Commander Starliner to operate a 5 Watt CB radio. I mounted it up behind the dash and it worked fine.Gary L.
Originally posted by Matt N View PostRadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
I put a modern radio in my 1954 3R6 pickup (6 volt, positive ground) and used this. It converts both the voltage and the polarity, if needed. Works well. Interestingly, it is made in New Zealand.
https://www.vintageautogarage.com/6-...V-p/ce412v.htmSkip Lackie
Good work! Are you going to try one? I wonder if it will switch polarity also. It almost looks like it will, but cannot be sure. For that price, it's worth a gamble.Last edited by Matt N; 09-23-2020, 09:51 AM.
No it doesn't switch polarity, but I believe if isolated the ground on the device (car stereo) you want to power.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
- 2 likes
The memory power will drain the battery if the car is not driven at least once a week. Maybe even more often since the car is 6 volts.
I hope you don't chop up the dashboard for that butt ugly radio.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by RadioRoy View PostI hope you don't chop up the dashboard for that butt ugly radio.
