63 avanti electric fan
  • Cool/Heat: 63 avanti electric fan
    Well I've thrown in the towel on trying to find a quieter alternative to the stock 5 blade fan on my 63 Avanti and decided to go with an electric fan.
    Surely someone has actually put an electric fan on a 63-64 Avanti, if so, what brand (part #?) did you use and did it perform satisfactorily. Only interested in experiences with 63-64 Avanti's due to their close fit between the front hub and radiator. Thanks.
    Then I won't waste your time with the one I put on my 74 Avanti in tight quarters.
    Bob
      That’s awesome!
      Fort Worth, TX
      1964 Avanti R2 #R-4986
        Bob
        I would love to hear about your install in the 74. I was just thinking that since the SBC engine in later Avanti's is about 1 1/2" shorter than the Stude 289 that it wouldn't be an apples to apples comparison. On the Studey the clearance between the lower hub and radiator is a little less than 3".
        Larry
          If a stock mechanical fan is too noisy for you, I wouldn't recomend an electric fan at all. Electric fans tend to be fairly noisy. At least any I've had have been much noisier than a stock mechanical fan, Maybe go to a clutch fan, or perhaps a flex fan , it depends on when it is noisy.
          The stock 5 blade mech fan on my GT didn't make any noise. At least until it got bent from hitting the shroud when an engine mount broke.
            Bob
            Excellent Bob!!:-)
              Larry
              Here's the install. Fan depth depends on where the fan hub lies relative to the lower pulley as there is some wiggle room. There's always a pusher but I'm not fond of them.
              This fan works for me but if it's too long you can use the specs to look at others.
              https://forum.studebakerdriversclub....fan-and-shroud
              If it looks like it will fit, I'll fire it up to give you a sense of noise. May be hard to hear over the engine though. Actually I can turn it on without the engine running.
              Bob
                Thanks sweetolbob, I'll use the info you provided to help with my decision.
                Delevant
