I'm confuse!
  • #16
    Great info all! I guess I have my work cut out for me?
    • #17
      Have you used a good multimeter on the battery to see what polarity it is? No, you don’t have to change terminals on the starter.
      • #18
        So I swapped the battery and it still starts and runs. The ameter needle motarily move but then stop as I cranked it up. There's no voltage change on the battery when rev the motor so I'm assuming the regulator has bit the dust. These regulators aren't cheap from what been able to find either!
        • #19
          Originally posted by Matt N View Post
          So I swappec the battery and it still starts and runs. The ameter needle motarily move but then stop as I cranked it up. There's no voltage change on the battery when rev the motor so I'm assuming the regulator has bit the dust. These regulators aren't cheap from what been able to find either!
          Did you polarize the regulator after changing the battery's polarity?
          • #20
            If the generator was polarized backwards, it will now not charge until you polarize it, aka "flashing the field".
            • #21
              Sorry for the late reply, yes I did. I think the regulator is bad I've ordered another one, and when it gets here l'll go from there.
              • #22
                Here is a segment of an old manual that covers troubleshooting the regulator. It is a very good idea to do the troubleshooting steps in order before swapping parts.
                https://1drv.ms/w/s!AvLlGFr3VITKlCGe..._rnRr?e=5CzJEd
                Nathan
                _______________
                http://stude.vonadatech.com
                https://jeepster.vonadatech.com
                • #23
                  Thanks for the link Nathan, I have a service mannual and I did test the regulator
                  • #24
                    Originally posted by gordr View Post
                    With all the stuff "broken", I am wondering if maybe somebody put in a 12 volt battery, and fried the dash lights, gauges, and other accessories? Then realized their mistake, and installed the six-volt battery. Backwards, because of course the 12 volt battery was installed negative ground.
                    That was my first thought also.
                    60V-L6 - 60 Lark convertible
                    • #25
                      No telling what was done in the last 70 years, I have very little history on this car, no telling what I'm going to find?
                      • #26
                        Years ago, I fixed a 37 Nash radio for a friend. Every tube in the set had a burned out heater. Very unusual for any one tube to have a burned out heater, but all of them? Well, you know what happened. Some folks just don't grok basic electricity.
                        • #27
                          Changed the regulator and now it charges and the amp gauge works! The other gauge still don't but I'm making progress!
                          Thanks for the help all
