quote:Originally posted by ma1951
Matthew,
I am the one you are referring to with the toggle switch. You just have to run a wire to the solenoid from toggle switch and you got it. All of the other overdrive components are just to control when the solenoid comes in and out.
Matthew,
If we do end up putting an OD trans in the car, what wires will I need to hook up, other than a wire from the switch to the solenoid? I would think a hot wire would need to be ran somewhere...
I don't want all the other 'components' that are needed to make the OD normally operate, just a simple flick of a switch to engage the OD whenever I need it.
I only intend to use the OD if I go out of town, which rarely happens. But if I do need to, it'd be nice to have the option of overdrive.
If nobody knows how to "Redneck Engineer" an overdrive, I'll just stick in another standard 3 speed and forget about it. [
Matthew Burnette
Hazlehurst, GA
