Hi, all: I just had my front brakes converted to Turner Disc (it's a '59 Silver Hawk). Have driven about an hour and a quarter since. I've just found that an abrupt pavement rise, such as a speed bump but even a bump-up on an urban street, produces troublesome contact sound on passenger side. It's loud and you can't miss it. No problem whatsoever on pavement dips, ONLY WITH A RISE. No problem with the turning radius. What could this be? I am running 15" Chrysler wheels with a 5 bolt pattern. No issues like this in the 3500 miles before the conversion was done. Driving Studes should not be a contact sport! Any ideas? Thanx.
Anybody got clearance issues with Turner Brake conversion?
Can you look underneath and see any shiny spots that used to be dirty?RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
I had to do a little grinding on the brackets (on both sides) of my Turner brakes when I installed them. (Car: 1964 Hawk, original drum brakes.) It has been several years since I installed them, so I can't remember exactly where I had to grind, but it was obvious when I installed them. If this might help I can run downstairs and photograph the brake (wheel is off, anyway).
--Dwight
Originally posted by Jeffry Cassel View PostGot a kit; didn't use it as it would have required too much butchery and couldn't see how I'd check fluid with bail type lid on res. Anyone want one? Good deal.
Bob
It's easy to understand WHY a Dual Master Cylinder conversion would work well on an Avanti!
It is Apples to Oranges to a under the floor Hawk M/C. That one, is one complicated, difficult to install and service mess.Last edited by StudeRich; 08-20-2020, 11:27 AM.StudeRich
Originally posted by StudeRich View PostIt's easy to understand WHY a Dual Master Cylinder conversion would work well on an Avanti!
Complicated and difficult to some not so much to others. Hopefully someone will be able to use this and make a safer driving (stopping) Studebaker.
Bob
To the original poster and subject: Take a look at the heater duct inside the right front wheel well. You may need to tie it up higher. My Hawk use to make noise on hard right turns or hitting just the right bump; that's what it turned out to be. The tire was contacting the duct.
