Tappet (valve) adjustment C: Commander 6 engine
  • Engine: Tappet (valve) adjustment C: Commander 6 engine
    Having never adjusted the valves on a flat head Commander engine...... I see some tight fitting of hands and feelers.... Any tips ??
    Not difficult, just awkward! You ARE Double Jointed right?
      You will want to remove the manifold set--far too awkward otherwise.
        I thought of the manifold set and possibly front fender. I'm concerned I'll never seal the manifolds again after removal......
          Have you got a pair of super thin tappet wrenches?
          60V-L6 - 60 Lark convertible
            Can't say I've ever heard of tappet wrenches ...
              They used to make thin open-end wrenches for adjusting valves. Probably still out there somewhere. Or get some cheap wrenches and a grinder...
              _______________
              http://stude.vonadatech.com
              https://jeepster.vonadatech.com
                Tappet wrenches look like open end wrenches, but are very thin so that two of them can be used in close proximity to, and opposing each other.
                https://www.ebay.com/sch/i.html?_fro...rench&_sacat=0
                  There are currently 6 pages of "tappet wrench" being offered on Ebay.
                    If the Block and Intake/Exhaust Manifold are "Plane" enough to seal now, I don't think anything will change when you bolt it back on with a fresh Gasket.
                    If anything, it will be better.
