Correct radio in 54 C
  • Interior: Correct radio in 54 C
    Checking fitment of the newly restored dashboard and inst, cluster in the Commander. Installed the pushbutton radio and the speaker assy. hangs well below the bottom of the dash. The present radio I have is a #2686 that came in the car. My manual shows it should be a #2680. My window sticker shows a pushbutton with roll up ant. Question is are these radios close to the same? Is the 2686 just plain wrong for my 54? Anyone have a 2680? I did not think I'd see so much of the radio speaker hanging down. Any info greatly appreciated.
    1942 Packard Clipper Custom Touring Sedan * 1952 Studebaker Champion Regal * 1954 Studebaker Commander Regal Starlight * 1967 Thunderbird Hdtp * 1969 Continental Mark III * 1969 Mercury Marquis convertible * 1972 Buick Riviera * 1973 Continental Mark IV * 1978 Glass Top Lincoln Town Car * 1983 Mercedes 300SD * 1986 Dodge RAM 4WD * 1999 Infiniti Q45
    AC-2686 is for the late 55 sedans and wagons with wrap around windshields. It's just plain wrong for your coupe. The AC-2686 has a different mounting angle of the speaker chassis to the tuner chassis than the other radios. That usually means that the push buttons will jam on the bezel if the radio is installed in a coupe.
    AC-2680 is for all 55 except sedans and wagons with wrap around windshields
    AC 2300 is for 53-54 all models and body styles. The only difference between AC-2300 and AC-2680 is the color of the numbers on the dial (early = white, late = yellow) the presence or absence of Conelrad symbols on the dial, and the size of the flipper on the tone control.
    The Conelrad symbols appeared in mid 1954, but I don't know if the dial numbers changed color from white to yellow at that same time or not.
    About 1/3 of the speaker chassis hangs visibly below the dash board. It is designed that way and supposed to be that way. That's why the lower part of the radio is painted dark gray, to minimize its appearance.
    60V-L6 - 60 Lark convertible
      Roy, thank you very much ! I felt things were not right when I was fitting things together.
        You are welcome.
          Bryan,
          Check Dannyo's post under CARS FOR SALE.
          He shows a lot of parts, including the radio.
          https://forum.studebakerdriversclub....-cars-for-sale
            Roy
            I don't think that the younger generation knows what Conelrad symbols are.
            There were two marks on the radio dial that indicated the location of the emergency
            radio stations where you dialed to when the Russians started to throw "A" bombs and you had to go to the fallout shelter in your basement.
              Originally posted by rkapteyn View Post
              Roy
              Run like hell to the Fallout shelter and duck and cover if you see a flash. Yup I remember. We still have Fallout shelter signs up in town.
                Jump under your desk and stay there for 2000 years.
                  Pic of the bathroom door in my garage: Click image for larger version
                    Roy
                    They are lucky to not have lived through that. Of course, there is plenty of news hype to worry about these days, too.
                      This AC 2300 fits my 54 Champion model W (four door sedan)
