Is the '65-'66 Studebaker 283" oil pan unique?
  • Engine: Is the '65-'66 Studebaker 283" oil pan unique?
    We've had discussions as to how the '65-'66 McKinnon 283" was identical to the US-built 283"s from Tonawanda.
    A member has asked for help locating a Studebaker oil pan and says it's different than "Chevrolet". Over the past sixty-five years, there are several different Chevrolet oil pans, but who can confirm the Chevrolet 283" oil pan from the same era is the same as Studebaker?
    If the Studebaker pan is different, what are the identifying features?
    jack vines
    I believe it is a standard Chev/McKinnon pan.
      Don't know about the oil pan, but I do know the air cleaner element is Studebaker only, as a standard Chevy 283 one won't fit in the casing/clear the hood.
      Bill Pressler
      Kent, OH
      (formerly Greenville, PA)
      All are in Australia now
        Call SI directly. They may have one even if not in their catalog.
          On that thread I think the answer was found? A Poster said that the 1968 and newer small blocks changed to a different Front Seal and Pan.
          So if that is the case, currently found junkyard small Blocks would have the wrong Pan.
          it "Probably" needs to be a 283/327 before that change.
            SI sold their inventory of 1965-'66 GM engine parts a little over a year ago: https://forum.studebakerdriversclub....s-gone-from-si
              https://help.summitracing.com/app/an...il-pan-seal%3F
              Regardless of the year the actual change took place, here is the info on the two pan sizes. cheers, junior
              1954 C5 Hamilton car.
                perhaps photos from this thread can provide any clues?
                https://forum.studebakerdriversclub....eering-factory
                cheers, junior
                  As Jack alluded to in his initial post, SBC's had several variants of oil pans in that era. My guess is that Studebaker was much more comfortable in designing the engine mounts to accommodate an existing oil pan that to get involved in stamping a new design for their use.
                  Also a different oil pan would require McKinnon to adjust assembly line conditions whereas the motor mounts were entirely in Studebaker's hands so they could just receive engines as needed.
                  Junior's post looks like a very generic SBC oil pan from the time to my old eyes.
                  Bob
                    Is the owner sure that the engine he has is an original McKinnon? It could be that it is a 283 from another application. If that is the case then the concept of the "Studebaker" pan being different might be because the one they perceive to be a "Studebaker" oil pan might not be. I'll attach a few photos of my McKinnon pan if that helps.
                    FWIW, I put an 85 Corvette 350 in my 64 Daytona that already had a (real) McKinnon swap. The pan on the 350 seemed a bit more forward (about an inch) and I used "Le' Mallet'" to ensure that it would clear the tie rod ends. When it was all said and done it might have cleared anyway as installed I had a lot of clearance. The tie rod ends are the only thing I can think of that might be an issue and at least in my case a hammer solved the problem.
                      McKinnon Engines require an Adapter to convert from the Original Canister with a drop-in Element Oil Filter to the Spin-on you have.
                        Summit Racing should have something that fits.
                        Tom - Bradenton, FL
