Diff ratio
    Originally posted by 61 Stude. hawk View Post
    There are 2 reasons why a C4 trans is being considered
    1 . I have been trying to source Stude. trans and associated parts since April but have had no luck
    2 . My mechanic who specializes in engine transplants etc recommended using a C4
    I could be wrong because I don't know the Man, but I doubt he understands the Challenges he would be facing and the additional Costs.
    The Machine Work Labor Cost alone could make it cheaper to get a correct fitting Trans. shipped from the U.S. or Australia.
  • JoeHall
    IMHO a 3.54 makes an excellent rear gear if behind an OD transmission. It yields a 2.48 final drive ratio in OD when using a T86, and 2.55 with a T85. Just about perfect behind a 289 or 259.
  • PackardV8
    Your experience is true to your experience. Also having owned both, that the Gen 1 Mustangs/Falcons weigh 2600-2800# versus the 3400# GT/Avanti, 25-30% lighter weight was why I felt the Fords feel faster.
    Both 225hp 289" engine ratings are essentially identical:
    Studebaker - 225hp @ 4500 and 305lbs/ft @ 3000
    Ford - 225hp @ 4800 and 305lbs/ft @ 3200
  • what huh
    Im curious as to how you are using the C4. this is the first i have noticed somebody wanting to use it on a Stude engine.
  • bensherb
    Just wondering if you could expand on what you've found to be the differences.
    I once owned a '66 Falcon 289" which came with the all-synchro 3-speed and a 2.80 rear axle ratio.
    Well, RPM for one. From my experiance the Ford revs both faster and higher comfortably; in stock form anyway. I've had MANY Mustangs, (basically a Falcon in different clothes) and all the V8 auto trans ones had 3.0 axles when I got them, as did my Thunderbird, But I do have 2.69, 3.25, 3.55, 3.70 and 4.11 third members as well. I've put way more mileage on with the 2.69, though for normal around town driving I like the 3.55 best.
  • 61 stude hawk
    1 . I have been trying to source stude trans and associated parts since april but have had no luck
    2 . My mechanic who specialises in engine transplants etc recommended using a C4
  • Hallabutt
    That depends entirely on the actual tire size. I went from 215-70-15 tires to 235-55-17 tires with virtually no change. The 17s are only about 1% larger in diameter.
    I'm not talking about low profile tires, which I think a complete waste on a stock Studebaker chassis.
    Bill
  • bensherb
    Originally posted by Hallabutt View Post
    If you think that you want a taller G/R, like a 3.31 experiment with a set of 16" tires and wheels.
    That depends entirely on the actual tire size. I went from 215-70-15 tires to 235-55-17 tires with vertually no change. The 17s are only about 1% larger in diameter.
  • Hallabutt
    You are the only one who can decide on what level of performance and comfort you want. If you think that you want a taller G/R, like a 3.31 experiment with a set of 16" tires and wheels. They should give you about the same gear change. Reread Jack's post #2.
    As for the trans change-your choice is a head scratchier. I guess if I didn't care about an OD, which I don't, I would dig up an available Studebaker Power Shift trans. It would be a lot less hassle. Parts are out there and you would keep it all Studebaker. Maybe you can explain why the C4?
  • PackardV8
    With the 2.54 Ratio Axle you had plenty of acceleration AND you could cruise comfortably at at 70 MPH.
    Of course, Rich meant the 3.54 ratio.
    The world and how we perceive the automotive experience changes every day. I grew up driving the 3.54 and 3.31 Studebakers and the passenger compartment noise and the heat were just the way things were. A few years back, I rode from Spokane to the Colorado Springs IM in a restored '55 Stude. It was 90+ for three days each way. We survived it but those who didn't grow up with that would have thought they were dying.
    Today, we've become accustomed to double-overdrive transmissions which cruise at 1500-1800 RPM, with sound insulation which quiets even that slight whirr, with electric fans which don't make a sound at highway temperatures and AC which enables the windows always closed.
    Bottom line, if there's regular highway driving in a restored Stude's future, consider spending some money on AC, sound deadening, sealing the firewall and a 3.07 rear gear.
    My Packard-powered '55 E12 has tall tires and is 2.95 in the T89 overdrive. It turns 2168 RPM at 70 MPH. Even that begins to be busy on the long stretches of interstate here in the west. However, sometime in the future, I'm thinking of building another TwinTraction Dana 60 with 3.73 gears and have a 2.68 top gear.
    Then, there's that Viper T56 six-speed with overdrive on the top two gears I've adapted to the Packard V8. Sixth gear is .50, so with the 4.10s in the truck, it would give a 2.05 cruising gear.
    It's all fun, however with only three speeds and a direct top gear, picking the sweet spot where the engine will be happiest is the challenge.
    To directly answer your question, the best Ratio for a Direct Drive Trans. with a 259 is the one the Factory most often engineered for good performance and cruising with good economy.
    THE Best all-around Ratio for the Torque/RPM range of that engine with a 1 to 1 Output Trans. would be the 3.31 Ratio.
    I am surprised no one has asked HOW the OP was able to get a C4 Ford to connect to a Studebaker 259!
    Input shaft, Torque Converter, Converter Housing, Throttle Pressure control all would seem to be a mismatch to a much newer Ford version of the old Borg Warner Ford-O-matic.
    Any change from Overdrive to a Direct 1 to 1 Ratio Trans. is very definitely a step Backwards in My and most people's book!
    With the 3.54 Ratio Axle you had plenty of acceleration AND you could cruise comfortably at at 70 MPH.
    UPDATE: corrected the Typo on the Ratio, thanks Jack!
  • Buzzard
    Jack,
    DR70x14" Really?? I haven't seen an alpha numeric size like that in decades!
    Jeffrey is correct as I have FMX guts in my FOM and it shifts superbly(hard but superb). I changed my ratio to 3:73 as I wanted the stronger acceleration but it does rev high on the highway -Approx 3000 rpm at 60 mph so you need to have your motor built to rev higher than stock. 3:54 is probably the best compromise.
    Bill
  • PackardV8
    The Fords that used the C4 typically had a 3.0/1 ratio rear axle, but, the small Ford makes power differently than the Stude.
  • chet445
    I went from four-on-the-floor to automatic on my '62 Gran Touismo and like the automatic much better. Problem is, I'm not sure what my speed is; need to have someone drive at a given speed so I might figure it out. Going from stop to a certain speed is a lot smoother and the car picks up its speed faster.
  • Jeffry Cassel
    C4 is a good transmission but an FMX is a great transmission. Why would you go to all the trouble to change from FMX to C4??
