A/C hose fittings
  • Cool/Heat: A/C hose fittings
    Anybody recognize this fitting? I bought some of these but they won’t fit my universal system. They appear to be metric of some sort??
      The one on the left....
        Metric fittings usually have notches around the nut. Your's don't fit because of different diameter? Measure end of tube and see.....
        #6 = 5/16, # = 8 13/32, # 10 = 1/2, and # 12 = 5/8.
        The fitting on the left almost looks like a quick disconnect type.
          Diameter is definitely metric so the crimp end doesn’t fit the hoses, and the o ring end is also metric and won’t fit universal compressor, drier, condenser or evaporator. The end looks different but not quite a quick disconnect. O ring slot is also different and appears to require a flat ring seal. I don’t know what this fits, some foreign system I suppose?
            They do make a female O-ring face seal to male flare adapter fitting. You need to go to your Pirtek or Parker fitting store.
            Bez Auto Alchemy
