Hello, I am at the point where I need to purchase a GM torque Converter. I have purchased an adapter plate made by Steel tech. I am using a rebuilt 259 full flow motor. Also, I plan to use a turbo 350 transmission. Steel tech recommends that I use a 10" torque converter. My 259 is stock. Can anyone recommend a torque converter or tell me your experience on this matter?
I need recommendation on GM Torque Converter
If you are putting this behind a stock 259, no R1/2 cammed unit,I would use no higher than a 1500 stall. A basic chev converter, C-9, will have about a 1300 to 1400 stall speed. The transmission shop that you purchase from can elaborate on slightly higher stall speeds. Most FLAPS counterpersons haven't a clue, so they end up calling someone "in the know" to answer your and their questions.Also it would help to know what bolt patterns the adapter flywheel is drilled for- inother words bolt circle diameter. Lou Cote [8D]
I put a stock Vette higher stall converter in my Studebaker streetrod project, On one of first outings ,the converter would not lock up (700r4) , trans temp went over 200 degrees in short time due to stall. What I am trying to say is,watch going with too much stall, it transfers into heat.
( have since fixed lockup and no problems now) Randy
Randy Wilkin
1946 M5 Streetrod
Hillsboro,Ohio 45133
Randy Wilkin
1946 M5 Streetrod
I have a mildly warmed over 259 coupled to a TH350 transmission in my M5 truck. I talked to the local speed shop about what had been done to the engine and how I wanted to drive it, and they recommended a stock converter. I bought one for the 1972 Chevy Malibu the transmission came out of. I think the stall speed was 1500-1800 but am not sure. In any case, it has worked fine for 13,000 miles. I also used the Malibu modulator.
Hope this helps
The TH350 is still a great choice of trans for a Stude conversion.
Plentiful, decent ratios, trick stuff available, and inexpensive.
I have a shift kit/stock converter in my truck and it is fine.
Sometimes I wish it had a higher stall converter in it, but a visit to the gas station makes me get over that...
O/D's are nice... But simplicity has some virtues, too.
A TH350 is about the closest thing you could get to a B/W 1st gear start A/T....and it is lighter.
Hope this helps
I agree. There's no need to putz around with a tricky O/D trans. for 99% of all Studes. To really get any measurable benefit you need to drive them a LOT more than most all Studes are.
I agree- K.I.S.S.
Unless of course one is going complicated just for the sake of going complicated
Parish, central NY 13131
