front end alignment
  • front end alignment
    Does anyone have any real world experince (ie. have you done it)
    Studebaker front end alignment using the Fasttrax tool that eastwood sells vs. the longacre racing fixture.
    Thanks
    Russ
    57 SH (project)
    60 Lark VIII 2dr sd (driver)
    53 2R6 289 5SpdOD (driver)
    57 SH (project)
    I have a Longacre (bubble) caster/camber tool and a toe in gauge (Harbor freight).
    Couple pair of dollar store pizza pans..
    Take one pizza pan, put a dab of grease in the middle and plop the second pan on top...
    Instant turning plates...
    Harbor Freight Turning plates $150...
    Mine $4
    (A Calvin Lowell Trick)..
    It'll take you all day to do your first one...
    But it will work.
    But get the Stude service manual first.
    Make sure to read how to center the steering gear.
    Thanks
    Russ
    57 SH (project)
      which mounting adapter do you have for the longcore, magnetic? or is there one that works with the stude spindle? I've reviewed the postings on the forum about home brewed front end alignment and would like to give it a try. I've got several stude front end rebuilds under my belt and two more scheduled in this month.
      thanks for the info.
      Mine $4
      But it will work.
      Thanks
      Russ
      57 SH (project)
      57 SH (project)
      57 SH (project)
        I use a magnetic Rebco bubble gauge but I also have the the 3/4"-16 spindle adapter that fits Stude spindle.
        Either will work. The more level the car the more accurate your results.
          I have both the threaded adapter and the magnetic mount.
          My Longacre came with the magnetic mount already on it and I have never swapped it out. The magnetic mount worked too easy.
          The magnet is pretty strong and once it's on you don't move it around anyways.
          Go for it!
          <snip>
