R2 carburetor mounting pads cracked
  • Fuel System: R2 carburetor mounting pads cracked
    Yesterday I removed my carb to rebuild it and found that it was cracked (significantly) at two of the four corner mounting pads (see pictures). Big disappointment--the car was almost driveable again after almost 2 years and much work. But there is no point in rebuilding this one. So I need to replace the main body (the lower 2/3 of the carb that includes the fuel bowls) of this 3588S Carter AFB for an Avanti R2. I don't need the upper part of the carb that has the plate with the text about it being an Avanti carb. Who would have original Studebaker carburetor parts like this? Or does anyone have a usable R2 "parts carb" (or at least this part of one) in their stash of spare parts? (Ironically, I had a spare R2 "parts carb" after my previous Avanti, but sold it on eBay a few years ago, thinking I would never have an Avanti again--yeah, right.) I also think this goes to show the importance of the torque specs in the shop manual.
    Thanks,
    Pete
ID:	1837629Click image for larger version
ID:	1837630Click image for larger version
    Pete R
    Woodbridge, VA
    1954 Studebaker Commander Regal Starlight Coupe with '62 289 and 4-speed
    1964 Studebaker Avanti R5083 R2 4-speed with 4.09:1 Twin Traction
    I'd start with asking Dave Thibault, 978-897-3158; he can rebuild your R2 carb as good a new.
      I will be interested to know if there is repair possible.
      Fort Worth, TX
        I had to weld up and re-machine a couple of them in the past. It can be done. Eric DeRosa Has one of my repaired ones on his R2 Lark.
        Bez Auto Alchemy
        573-318-8948
        http://bezautoalchemy.com
          The best way to go with this since you have a good Top Half, is get a New Edelbrock AFB Clone and put your top on it and Seal it as others have done.
            Since posting this AM, thanks to a Studebaker neighbor, I have located a replacement R2 "parts carb." Thanks to all who replied.
            Pete
            Pete R
            Woodbridge, VA
              As Brad mentioned, he welded up the pad on my R2 carb a few years ago, and so far, so good! Thanks Brad! Here's a picture of what it looked like before Brad repaired it.
Name:	nov 21 2016 import 262.JPG
              Eric DeRosa
              \'63 R2 Lark
              \'60 Lark Convertible
                Word of caution..
                With thicker heat insulating gaskets being all the rage, it is easy to over-torque the mounting nuts and crush the thicker gasket material.
                Studebaker service manual spec for a 5/16"-24tpi V8 carb mount stud/nut is only 11 to 17 ft.lbs. torque.
                I would suggest using the lower number.
                (HTIH) Hope the info helps)
