Alternator Conversion
  • Electrical: Alternator Conversion
    I have a 259 V8 in a 60 Lark , Does anyone have or know of a bracket I can buy to install the Alternator replacing the generator?
    I have attached photo's , Any help would be appreciated.
    1960 Lark VIII Convertibe
    1964 Daytona *
    1956 Stude PU *
    1951 Stude PU *
    1963 Lark *
    1960 Lark Regal 4 door *
    *= previously owned.
    yoyoman, there were no photos attached to your post. BUT, I went out and took pics of mine on our 55 coupe. Looks like a real simple home-made thing to me, but glad you asked the question, because now I see a nut that needs tighte Click image for larger version
ID:	1836069 ning, ha ! Click image for larger version
ID:	1836067Click image for larger version
      Most of the time you can use the generator bracket with a long bolt and a spacer to take up the extra space not used by the alternator. The trick is getting an adjusting arm to fit and a belt.
        Thanks for the info!!!
        1964 Daytona *
        1956 Stude PU *
        1951 Stude PU *
        1963 Lark *
          When I converted our 63 Lark over to a later GM one wire alternator, the GM alternator mounting point was a little narrower than the original, so I just shimmed it up with washers. Works great for 11 years now. Set your new alternator down on your braket and seewhere you are at.
            Thanks Waydon
            1964 Daytona *
            1956 Stude PU *
            1951 Stude PU *
            1963 Lark *
