Fuel pump
  • Fuel System: Fuel pump
    Ok,I am working on my 49 COMMANDER dual action fuel pump, I have fuel spitting out of the 2 little holes above the bowl. Click image for larger version
    I'm thinking the fuel pump diaphragm has failed causing your problem. You will either need a new pump or rebuild your present pump. Bud
      I was thinking that also, the wipers are not working either.
        Time to rebuild. Years ago my bosses car exloded one morning as he tried to fire it up to go to work, A pin hole in the diaphram of the fuel pump had filled the crankcase with a very explosive gasoline vapor. First cylinder to fire set the bomb off.( He was uninjured but embarassed.)
