DG-200 leaking issue
  • Transmission / Overdrive: DG-200 leaking issue
    Hello,
    I recently rebuilt my DG-200's front pump ad unfortunately it is still leaking at the same place as before between the torque converter housing and the transmision itself and as much. To make the situation confusing for me is it wasn't leaking before I drove it for a final test and was working fine as intended.
    What could be the leaking problem if it's not the front pump? Could it be the transmission fluid that isn't the right one for the transmission? Right now I'm running out of ideas. If you know what could be the problem let me know.
    Max
    Sometimes when the front seal is being replaced the garter spring inside the seal gets knocked out of position. It's best to pack the inside of that seal with Vasoline or something similar before installation..
    "Burning Bridges...Lost Forevermore"......
