Front leaf spring curve
  • Front Axle / Front Suspension: Front leaf spring curve
    So I temporarily put tires and wheels on the front end of my frame...... and not sure how much curve the front springs should have. No transmission or cab on the springs, and they already look pretty straight instead of curved.
ID:	1832311Click image for larger version
    I realize rather hard to see in the photos, but the leaf springs have minimal curve to them. Should they have more curve to them?
    Mike and Dawn
    '61 Champ
    That IS a tough call not knowing what they will look like with a completed truck on them.
    But I will say that those ARE pretty Rigid Truck Springs and may not "Flex" much more.
    I don't know, but I would "Think" that Shops that Re-Arc Springs would be able to tell the tension they have left and if they are close to "Spec".
    Are those NINE Leaf Springs?
      Those springs do tend to loose some of their "spring" as then age. Below are the old springs on the front of my 7E5. Minus some fluids and a battery, all the weight is there that would normally be. They are the heavy duty version for the six cylinder trucks, but you can see the one of the left is pretty flat compared to the one of the other side. Will probably break down and buy a new set - worried that it might want to wallow when driving and make it perform poorly...
        I will call the place that did my kingpins and ubolts, see if they can test, or measure the springs.
        Currently its 8 leaf springs. All I have.
        Thanks for the input,
        Mike and Dawn
        '61 Champ
          Thanks for the photo. Mine aren't quite as flat as yours on the left, but I don't have the heads on the engine, or the transmission bolted up either. So, guess I will see what can be done with mine, or maybe buy new ones. Thanks again for the photo.
          Mike and Dawn
          '61 Champ
            I took some pictures of my front springs . 64 Champ 259 , automatic . I believe this truck was a 6 cylinder as the springs are only 5 over 1 but I have not run the #s yet . It has definitely been changed around a bit . When I got the truck last year the springs would clash on the snubbers over even a small dip . They had a reverse curve on them and the front end was low . I had them re-arched and I pressed in New bushings and I think they are pretty good now , there was a big difference .
            hopefully you can see it enough
              IIRC, some Stude pickups have a left and a right front spring. Supposedly, this is because the weight of the fuel tank, the driver, the battery and the steering box are all on the left side; for the truck to sit level when loaded and go down crowned roads without pulling. Anyone else have part numbers to confirm this?
              This I do know from experience; the Stude pickup spring eye bushings are junk and always pound out in too-few miles. The design with the shackle bolt chewing on the spring bushing rubber is just wrong science. If one is having new springs made, or even having them re-arched, change the main leaf to one with a larger eye to accept a hard spring bushing with a center steel sleeve.
              jack vines
                On my 7E7 with 289 and bias 6.70-15’s at 25 psi, the front spring eye center heights are roughly F = 13.5” and R = 11.5”.
                  jack vines
                  This is correct up to 3E series. After that both front springs same.
                    Thanks for the information and photos, that is helpful. Looks like you have 6? leaf springs up front. And they have more curve than mine with 8.
                    Mike and Dawn
                    '61 Champ
                      I think my rear leaf spring bushings had the center steel sleeve, but not the front ones. Thanks for the tip.
                      Mike and Dawn
                      '61 Champ
                        Thanks for the information and photos. I'll see how that compares with mine.
                        Mike and Dawn
                        '61 Champ
                          According to the parts book, the standard front leaf spring for 7E trucks (1/2 or 3/4 ton) with a V8 would have 9 leaves - the heavy duty would have 10.
                            Actually, the 8E series did have different right and left front springs.
                            Paul
                            Winston-Salem, NC
                              Yep, you're correct. Now I wanna know why.
