Hello to all .New to you . I’m looking for a T85 with R11 overdrive to install behind SBC . So how to adapt it what do i need to do . Read many articles but got only bits of info . Most Trannies of this type came from Studes so . I can make it work . I Bow to the Knowledge of those who have gone before me . Thank you 🙏 Karl
Advice needed: How to adapt a T85 with R11 overdrive to SBC engine
Tags: None
Welcome to the Forum, Karl!
I can't help you with your inquiry, but I'm sure you would attract folks who could if it had a more descriptive title than "Advice".Brad Johnson,
'56 Sky Hawk in process
That trany was used in...
1957 - 1966 American Motors/ Rambler with 287 or 327 engine.
1965 - 1969 Jeep J-series 4WD pickups (used with a Dana 20 transfer case)
1963 - 1967 Jeep 4WD Wagoneer and Cherokee with a V-8 engine
1965 - 1971 Ford truck
1955 - 1958 Packard
1962 - 1964 Plymouth with 413 or 426 engine
1964 - 1965 Buick
1960 Dodge Dart, Matador and Polara
1956 Studebaker
1957 Nash Ambassador with a V-8 engine
1957 Hudson with a V-8 engine
1958 Edsel
1955 - 1957 Mercury
1958 - 1964 Pontiac
1962 - 1963 Oldsmobile
MOST did not come from Studes. You need to find out what you actually have in order to adapt it to a Chevy.
It is essentially a BW T10 four speed with only 3 forward gears.
Unless you have to have a column shift, a WC T5 would be a better and less expensive way to get the OD.Dick Steinkamp
Bellingham, WA
- 1 like
There are a dozen varieties of the T85 overdrive transmission. The most important is the front bolt pattern and the second is the input shaft.
Give us more details and we can help you find what you're trying to accomplish.
FWIW, I have the ultimate example of this ; a very rare SBC 4-speed T10/BW R11 overdrive conversion done by our friend Alan.
jack vinesPackardV8
Originally posted by Gear Head View PostHello to all .New to you . I’m looking for a T85 with R11 overdrive to install behind SBC . So how to adapt it what do i need to do . Read many articles but got only bits of info . Most Trannies of this type came from Studesso . I can make it work . I Bow to the Knowledge of those who have gone before me . Thank you 🙏 Karl
1965/67 Galaxie/LTD 352/390 /// 1955/56 Packard/Clipper.
Originally posted by Dwain G. View PostSeems like you should be looking for a Saginaw trans with BW overdrive. That's what would have been in a late '50s Chev.Dick Steinkamp
Bellingham, WA
Originally posted by Dick Steinkamp View Post
X2...plus, the later version of the Saginaw 3 speed had a synchro low. The Saginaw 4 speed had the same case as the 3 speed, and like Jack's OD addition to a BW T10, you could add the Saginaw OD to the 4 speed Saginaw.
jack vinesPackardV8
Gear Head , welcome to the Forum. For future posts, please remember to put technical topics in the Tech Talk channel, and choose the appropriate topic prefix for the question you're asking. Also, make sure your topic title is as descriptive as possible - let people know what you're asking about. You'll get more responses, and it will help users later who may be searching for the same topic.
Happy Studebakering!
Thank you all for “Advise”
I’m retired first ever joining a Car Club . Was born with Bow tie umbilical but was told by my fathers. Motorcycle riding Buds I was Created on His favourite Snort-in Norton That was at Dads Funeral . Wonder why I like Riding Motorbikes 🏍 I will post in Tech area with better heading . Really want to put old style overdrive in my 57 Chev and you Stude men seem to want to make the impossible work . It’s easy if you have lots of money and can pay someone else to Do it . I love making it Run and Sound Sweet . I have a Saginaw 3 spd full synchro I put in and still use column shift which I just love don’t want floor shift . So I can get 1960 Studabaker t 85. With R 11 Small Ford bellhousing pattern 10 spline clutch. Long pilot nose and yoke output on tail shaft .
Your build, your money, your decision, but if you've already got the Saginaw 3-speed with overdrive, the only conversion which makes much sense is to put the OD behind a Saginaw 4-speed. It all fits with no problems.
Having been there, done that, wanting to mess with the T85 behind a SBC is doing it the hard way for no gain.
jack vinesPackardV8
